Question about Dacor Grilling
Our complex has two Dacor BBQs. Both give off very low heat. It takes 15 mins to get the temp up to 300 and that's as high as it gets. The flame to me look low (weak). Many times the flame cannot make it around the U-shape burners even when assisted with an open flame. I've bored out the holes in the burner and that did not help. Is the problem the regulator or the gas input line?
  • Dacor Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
The heat exchanger is burning due to high limit saftey stat. What should I do
The high limits are designed to shut the heater off if the water temp exiting the heat exchanger gets too high. One is set at 135f the other at 150f. The thermostat should shut the heater off once the pool water gets to temperature.
I'm not sure what you mean by "burning". The operating temp in a 400K btu heater is around 2000 degrees. If you are getting a lot of "sooting" that is typically caused by low gas supply. That's where you get orange flame instead of blue flame. Can you give me more detail?
Nov 23, 2013 | Pool & Spa
The heating in my 2001 Crown Vic is delayed for 15-20 mins. It has been aprox. -10 to low teens lately. Do you know the issue?
With the outside temp being so low you can expect the heating in the vehicle to take longer to heat up and possibly not be as hot as if the temp was somewhat higher.
Jan 05, 2011 | 2001 Ford Crown Victoria
Dacor oven heating coil broke on one side
no it wont work and it would probablr run between 200 to 300 dolars give or take a little
Mar 17, 2009 | Kitchen Ranges
FURNACE CYCLING ON AND OFF ..
I would check furnace filter first. If that looks good i would check the thermostat. To check thermostat turn power off to furnace then take thermostat off the wall and connect wires labbled R & W together then turn power on and check furnace to see if it runs for more than a couple of minutes. If so install a new thermostat. If that doesn't work let me know and i can give you a couple more thing to try.
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Poetable AC compressor licks in for 10 min
It is probably either the high pressure switch or the frost control. The high temp switch usually trips because the condenser coil is dirty which does not allow it to exhaust heat very well. The frost control will trip if the system gets below 39 degrees on the pipes. This is usually do to low refrigerant or dirty filters. Good Luck!
Jul 03, 2008 | Maytag Portable Air Conditioner M6P09S2A
GE XL44 Spectra Gas Oven Range
Replace the electric ignitor, I did today... Temps are hotter than ever. $60 from an appliance suplier, easy to install.... Trust me
Jun 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Grilling Logo
123 people viewed this question
Top Dacor Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Dacor Grilling Expert? Answer questions, earn points and help others
