Question about Watches
I have a cigarette lighter from the 2000 Olympic games but it will not spark. Can you help? Kym
  • 831 Answers
Thanks for contacting FixYa.
First check your fuses. If that isn't the problem try this: take a small flat head screw driver and gently bend the two prongs out a little bit. They are used to hold the lighter in place so that it will operate properly. If your lighter works with the key off remove the fuse first. As for replacing the lighter there are two wires connected on the back side you'll need to remove them. On some lighters you will have to unscrew the outer body to remove the lighter others have a nut that has to be removed. Access to the back side of the lighter is always a pain and how you gain access depends on the make, model and year. I hope this helps you.
Posted on Sep 03, 2010
Cartier lighter- doesn't hold the flame. Major problem? Thank you.
Anon, Check the attached links,instruction and guides to trouble shoot lighter problems. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.cartier.com/services/expertise-guide/care-recommendations/care-recommendations-lighters/flame-adjustment-screw-566.html
Quick Tips on Getting Your Lighters Working Again
How to Troubleshoot Lighter
Fixing that jet lighter you love
May 17, 2016 | Cartier Watches
Colibri cx gear 35002 butane lighter
I.ve got a lighter its silver crome alluminum it reads on both sides a big X with a c on top and us on bottom its butane on the bottom it has a signiture I.D it looks like a snake going up a stick can you help me idenify this lighter it's driving me nuts Thank You Lily
Sep 22, 2012 | Watches
My problem is that i can't find an postal or email address for somewhere reliable that i can send my old colibri 'molectric' cigarette lighter for repair. can anyone help? this lighter has great...
mcdevito75 here, Hello Dave, My advise is to take your lighter to a jewelery shop, you can try a small place, they may have the info or even repair your lighter. Also try Colibri watches.com try and see.
Feb 11, 2011 | Watches
Flint spring & screw for monopol lighter
mcdevito75 here, Best Bet, Shop ebay for a similar lighter, flints you can buy at most stores that sell cigarettes.
Sep 29, 2010 | Colibri Watches
Refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
Jan 23, 2009 | Dunhill Watches
Colibri lighter
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Dec 20, 2008 | Watches
Cant keep time
there is adjustment for that inside of watch or it just may need a little cleaning inside recommend take to jeweler and have serviced if you want to try cleaning at home simply take off back cover and clean with a little cigarette lighter fluid put little bit in wash around and drainout (do not soak) allow excess to evaporate out and replace battery and cover hope this helps
Sep 05, 2008 | Timex 27191 Wristwatch
Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn ghelfne1@nycap.rr.com
Jan 30, 2008 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
