Question about Minn Kota GPS
Minn Kota Rheostat
I need a Rheostat for a Minn Kota 65, 28# thrust, 5 forward, 3 reverse. Extension tiller, click to change speed. Do you stock one, or do you know where I could get it. Thanks for your time.
Jim.
SOURCE: mINN kOTA 70 LB THRUST FOOT CONTROLLED TROLLING MOTOR
VONNY MY MOTOR DOES THE SAME THING AND I FOUND THAT THE DUST OF THE MAGNETS IN THE HEAD WAS CAUSING THE MOTOR TO STICK I CLEANED INSIDE WITH ELECTRICAL CLEANER AND IT STARTED TO WORK FINE BUT YOU MAY HAVE SOMETHING ELSE GOING ON AND ALSO MAY SURE YOU ARE NOT COVERED UNDER WARRANTY IF YOU JUST GOT THE BOAT
Posted on Jan 21, 2008
SOURCE: minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Posted on Aug 03, 2008
SOURCE: minn kota 65
IF YOU HAVE CHECKED FOR WATER AND THE MOTOR UNIT IS DRY, DO YOU HEAR CLICKING COMING FROM YOUR MAIN CONTROL BOARD? IF SO THE MAIN BOARD WOULD NEED TO BE REPLACED.
Posted on Aug 07, 2008
  • 8 Answers
SOURCE: Minn Kota lower unit leaking.
Man, you have a job ahead of you. First, if the unbreakable shaft is cracked or broken, you will have to replace it, for it will leak into the motor too. If your unit has the sonar sensor in the front and it has had water in it, the unit can corrode severely and need a lot of parts besides seals. The wiring to the sonar runs in a protective shield bonded to the magnet housing and one of the long screws holds it in there. Remember to take the wiring to the sonar out AFTER you remove the big motor feed wires, and replace it BEFORE you reinstall the red and black cables. Some grease seems to ensure the o'rings slide on metal parts during reassembly rather than tear. It's quite a job.
Posted on Nov 28, 2008
SOURCE: what size battery does a minn kota 565 5 speed
12 Volt
Posted on Jul 17, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota trolling motor has forward but no reverse
    Don't know what Minn Kota you are talking abut but my 55 pound Thrust one does NOT have a Reverse.... When I want reverse I swing the Prop all the way around so it is pulling the boat backwards..... I just checked it to refresh my memory......
    May 08, 2014 | Minn Kota Boating
    The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
    A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
    Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
    I have a 5 speed forward minn kota only 3 speeds work ,I replaced the speed control box but have the same problem
    Check the Relay's these will be found in the control module, Most likely totaly sealed, test or replacement may be required
    Aug 26, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota electric motor MKJI1033962
    Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
    800-227-6433 they will help you with any technical questions.
    Parts can be purchased from this dealer...There are schematics on the site for review....
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    =100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
    Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
    Wiring diagram for Die Hard 28 lbs thrust trolling motor
    It's probably a Minn kota with a die hard label. Call Minn kota and ask them.
    Aug 08, 2008 | Boating
    GPS Logo
    173 people viewed this question
    Top Minn Kota GPS Experts
    Will Halftowaite
    Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
