Question about Samsung L210 Digital Camera
When i press the power button, the LCD shows a blank screen and the zoom lens is stuck or seems so. i have tried taking out the battery and leaving it out for a while then putting it back in but still not working
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
My sanyo vps-s1414 camera seems to shutdown when I take pictures - i take a picture and the lcd screen goes blank and the green light showing the camera is on goes off but the lens stays out. I have to...
1. Try cleaning the battery contacts inside the battery compartment.
2. Try removing the media card, then turn on camera. If its ok, then you have a bad media card, try formatting the media card.
Jul 31, 2011 | Cameras
LCD screen is blank in normal picture mode. I
This Camera has an CCD issue. It seems that the CCD of the Camera is gone bad. However, you may try resetting the Camera to the factory settings. If the issue persists, try power resetting the Camera. To power reset, remove the battery of the Camera and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 26, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
I have no LCD screen when my E300 is turned on, it stays blank until I take a shot, the LCD screen shows this shot for a couple of seconds and then blanks again.I can't seem to find the problem in the...
Have you tried pressing the 'INFO' button? This little button will toggle between camera info on display/no info on display (when the display isn't in use to display pictures).
Oct 19, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
Turns off right away
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
rate me!!!
May 24, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Zoom Error
try to manually adjust the zoom. My camera is doing the same thing. sometimes I can get it to focus after forcing the camera to zoom in and out a few times. No one well let me know how to get hold of a repair manual to adjust this, but when I figure it out I will post it.
Dec 14, 2007 | Fuji FinePix A345 Digital Camera
Blank LCD on the camera
The camera turns on but the screen stays blank and I press any button and do not do anything no zoom no nothing and I press the menu button but neither nothing shows up just the blank screen
Jan 16, 2007 | HP Photosmart 620 Digital Camera
Samsung L210 Digital Camera Logo
60 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
