Question about Weather King 10AJA3601AH Air Conditioner
Weather king Aj3601
The unit will come on and might be okay for a couple of days, then again it might stop within a couple of hours. It comes back on after a few hours, why is this. Next My unit was running fine but when I walked in the hall where the filter is I smelt a strong oder that smelled like oil or something and thought I seen some fog like smoke hasn't happened since but i took the filter an electronic something or another, Its a reusable filter, and tore it down and cleaned it real good. Still we have the problem of it shutting off and taking forever to come back on. Miserable please help
  • J Wesley May 10, 2008
    But it only did it that one time?? It works fine at night its during the day its started this ****. It will do fine til about 12 or 1 and shuts down til 7 or 8????
    Yes about a year or less ago, But took off the grill a week ago and it looked good. I can turn the attic fan on and it seems to help it kick in sooner.
  • 770 Answers
Sounds like you have a freon leak hence the smel of oil and fog the unit runs because it has a low pressure cut out to protect the compressor when the pressure builds up enought to close this switch the unit runs as thwe pressure drops the switch cut off you will need to have a leak test done on the Evaprator coil inside
Posted on May 10, 2008
  • Gary Davd
    Gary Davd May 10, 2008
    it could be tripping out on hig pressure as well have you taken a garden hoase and washed the outdoor coil off
Our chev 2003 pickup will get reduced engine power. We can pull over kill it a couple of times and go again but the engine light stays on but it may do it several times within a 20 mile drive. Then if we...
Since I have no idea where you live and what the weather is, I am asking if your engine is carbureted. In cold and damp weather, I had a similar problem which was cured by warmth from the engine heating the carb. (It was called carburetor icing.)
Oct 28, 2013 | 2003 Chevrolet Impala
My Weather King AC unit model number 13AJA48A01 is freezing over. What can I do to fix it.
Hello my name is Heath it will be my pleasure to assist you. First be sure that the blower is working next make sure the filter is not plugged. If these two things are okay then you probably have a low freon charge in the system. Which also means you have a leak so I would have the system leak checked and repaired before having someone just dump freon into the unit as its just going to leak back out.
Oct 09, 2010 | Weather King 12AJA6001AH Air Conditioner
FAN WILL RUN BUT COMPRESSOR COMES ON WHEN IT WANTS TOO. WEATHER KING 12AJA4201 PS LAYED OFF OVER A YEAR PAYMENT COULD BE A PROBLEM YOUR HELP WOULD BE A BLESSING
weather kings are like that (junk),i install 8 or more a week on new houses,they all do that.yours is a 3.5 ton which is what i set.if the t-stat calles for a/c within 5 mins of it turning off after a cycle,the compressor has a protection built in which keeps the compressor from coming right back on when it just stoped.they say its to keep it from burning up from going on and off alot.
Sep 24, 2010 | Weather King 12AJA6001AH Air Conditioner
2004 Excursion/Powerstroke/ On Warm days, ac loses power. I turn the key on and there is no lights on the AC. Then, it comes back on and works again. Sometimes after couple of hours. I am assuming there is...
Could be the relay, the controller, the temperature sensor in the coolant system, the compressor, the R-134 level in the system, etc. What is SOUNDS like is that you may have a bad ignition switch or trouble with your harness. At any rate, the intermittent nature of it (I'm assuming that when you say "it comes back on and works again" that it works normally during those times) suggests a likely electrical issue.
May 02, 2010 | 2004 Ford Excursion
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather king ac not working at all
see if there is a switch at the furnace that may be off.check the doors as well for tightness.If that doesnt do it,you may need a pro.
Aug 05, 2008 | Weather King Heating & Cooling
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Heater works after being off a while
If the unit is remote control try to unplug the supply of the unit(or off and on again circuit breaker) and operate the unit again. If it wont work then call a qualified technician to check the unit, maybe there is a problem with the unit control.
Dec 21, 2007 | Weather King 12AJA4801AH Air Conditioner
Weather King 10AJA3601AH Air Conditioner Logo
74 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
