Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear wpn824- no disk
HELP. I am trying to reconnect after resetting defaults. I am looking at a once working wireless just sitting there... lifeless. Where did I go wrong?
  • 6,487 Answers
How many computer do you have and what OS are you using on those computer?
Posted on May 10, 2008
  • Mark Gil
    Mark Gil May 10, 2008
    If your running xp follow this:
    Right click on wireless icon on the bottom>view available wireless network and connect to your own network.
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
I cant find the password for my netgear
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Jan 30, 2011 | NetGear RangeMax WPN824 Wireless Router...
Reset password
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Mar 06, 2010 | NetGear RangeMax WPN824 Router
Netgear wireless router wireless light won't light
Once \you reset your router, the router must be set up again in orser to use it wirelessly. Connect with CAT-5 cable router to computer, go to http://192.168.1.1 log in to router with name = admin and password left blank. Go into the Wireless section, set your SSID (Network Name) and whatever security you want to use. Write it down, do not forget, you should be back on line. Contact me if this does not work jaye.ellen@gmail.com
Dec 19, 2009 | NetGear RangeMax WPN824 Router
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
I had my Laptop worked and it was reset back to out of box
You need to RESET your wireless router. Her is how: Press and hold the Default Reset button until the test light blinks on (about 10 seconds). Release the Default Reset button and wait for the router to reboot. The default administrator's password is password The default IP is 192.168.1.1 Hope this helps
Jun 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need to get into the router settings , but the default username and password aren't working, I've already held the reset button down for 30 secs and tried login admin:password , but no luck...
Since you already tried steps 1 thru 4, give steps 5 and on a try
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Mar 05, 2009 | NetGear RangeMax WPN824 Wireless Router...
Reset my router netgear
just press the reset button at the back of your router (there's a tiny hole near the ethernet ports, you need to use a pin or a paper clip) for like 30 secs to a minute and power cycle it. (note
you can also do a software reset, just follow the steps below:
  1. Type 192.168.1.1 in a Web browser
  2. Click on Backup Settings
  3. In the Revert to Factory Default Settings click Erase
Note: Do not try to go online, turn off the Router, shutdown the computer or do anything else to the Router until the Router finishes restarting! When the Test light (looks like a check mark) stops blinking, wait a few more seconds before doing anything with the Router.
do remember that all your settings will be deleted once you reset the router.
hope this'll help you
ciao
Nov 09, 2008 | NetGear RangeMax WPN824 Wireless Router...
Can't reconnect - NetGear RangeMax WPN824 Wireless Router
Try changing the channels of the router to 1,9,or 11. this may help minimize wireless interference.
Mar 27, 2008 | NetGear RangeMax WPN824 Wireless Router...
Reset
You can reset your Netgear router/wireless wpn824 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless wpn824 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear wpn824 router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the wpn824 router has been reset.
Feel free to get instant online Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Dec 15, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
57 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
