Question about Yamaha DVD-S2500 DVD Player
DVD S2500 won't power on. I can see LED for optical connection so know power is getting to the unit, but unit does not power on.
3 Suggested Answers
SOURCE: yamaha s2500 dvd player
If the fuse is not blown then buy a new one!
Posted on Apr 08, 2007
Hello, frustrated Yamaha owners.
I have destroyed two of these machines to remove my precious CD's. I did discover this today:
1. There is a fuse but it is soldered onto its circuit board.
2. There is no easy way, like using a paperclip on the old computer cd-rom drives, to release the cd/dvd tray. However, when I destroyed my second player, I noted there is a rather large piece of metallic tape on the bottom of the player to the right side of the front of the drive on the metal bottom cover plate of the machine. It is covering a slot about an inch long. If you carefully remove the tape and use, say a phillips head screwdriver, starting at the right side of the slot as you face the front of the player, you can slide a plastic bar that will free-up the tray slightly allowing one to pull the tray out and save the cd or dvd. I would do this with the player upright but hanging over the edge of a table so that the freed cd doesn't bang around against something in the process.
For what it is worth, I hope this helps.
Yamaha should be ashamed of producing a product at this price point with an issue like this. At the very least there should be a fail-safe way of removing a cd/dvd from the drive regardless of the issue with the electronics or drive mechanism.
Posted on Mar 15, 2009
How can a make multiregion my sony bdp s2500
Sony BDP S1200 - Region hack ?. - VideoHelp Forum
forum.videohelp.com > Forum > Hardware > DVD & Blu-ray Players
Dec 14, 2014 - 13 posts - ‎7 authors
Hi peeps, My old Phillips Blu Ray gave up the ghost this week, ... especially bluray players. usually only the dvd side can be made region free. Sony BDP-S2500
Nov 30, 2015
Jan 26, 2010
Samsung BD-P2500 - All Regions Hack Required
Dec 1, 2008
More results from forum.videohelp.com
Multiregion sony bdp s2500 - Fixya
www.fixya.com/support/t25991992-multiregion_sony_bdp_s2500
3 hours ago - multiregion sony bdp s2500 - Sony DVD & Blu-Ray Players question. ... How can a make multiregion my sony bdp s2500 Multiregion. Dec 03 ...
Sony BDP-S580 multi region DVD hack with URC-3440 ' AVForu
Dec 03, 2015 | Sony Televison & Video
Why my portable dvd playing won't play when i put a dvd dics in?
If it takes and accepts the disc but will not play it is either a mechanical issue (table not spinning the disc) or if not reading disc it is likely a dirty or bad optical pickup in the unit---
Nov 03, 2012 | Televison & Video
I have a ripspeed DVD 720 when I wired it in the power button just flashed red for a bit and that's it it won't turn on or do anything?
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Oct 06, 2012 | Televison & Video
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
My treadmill was going slow and speeding up and keeped doing that when I would start it. Now it won't run at all! Do I need a new motor or is it the wiring?
Optic Sensor MOTOR Signal Test Procedure
Turn on unit power. Do not press display keys. Use your hand to rotate the motor flywheel. Normal result:
LED 10 lights to indicate the optic sensor signal entering the drive board. The LED appears to flicker at a
low speed and remain lit at high speed.
Optic Sensor MOTOR Signal Test Results
If LED10 does not light, inspect:
1. Optic sensor signal wires and their connections; Reinsert wire ends into connectors.
2. Whether optic sensor wheel rotates in the middle of the sensor; If not, reinstall the optic sensor wheel.
3. Whether optic sensor wheel teeth are broken or bent; if so, replace the optic sensor wheel.
4. If LED2, the VCC circuit indicator, on the drive board lights and there is no optic sensor signal output
(LED10 does not light), and if optic sensor wires and connections are good, replace the optic sensor.
Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Oct 01, 2011 | Proform 380 CS Treadmill !
CH-DVD 320-won't come on at all. Used to work fine. Now won't come on, it's dead.
If your unit has no led light lit on the front panel, this is an indication that the power supply board is not working(dead).
First thing to check is the basic, I'm assuming that your outlet is live. Check the continuity of the power cord using the multimeter. Sometimes it has an internal broken wire due to frequent pulling and bending. If the power cord is good, open the top cover of the unit and check the internal fuse. Sometimes due to voltage surge and aging, fuse fail. If this is the case, replacing with same current(ampere) ratings will cure the problem.
Let me know if the fuse is intact or blow again after the replacement to determine the next steps.
Jdvillanueva
Jul 11, 2011 | Televison & Video
My computer doesn't recognize my optical drive within the BIOS or windows (HL-DT-STDVDRAM GT31N ATA Device ) in windows7
If BIOS won't detect the Optical Drive, try reseating the SATA cable connection from the ODD to the mainboard. it might be have troubles detecting it due to a loose connection.
May 04, 2011 | Hitachi Computers & Internet
Yamaha DVD-S2500 DVD Player Logo
46 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
