Question about Canon imageCLASS D860 All-In-One Laser Printer
We have the Canon D860 Digital copier and believe there is a malfunction in the ADF. There is an even black line down the right side of the page that only appears on copies sent from the automatic document feeder. Any ideas?? THANK YOU!
Soulvisitor
  • 1113 Answers
SOURCE: I need a new ADF (automatic document feeder), where can I get one?
ADF can be bought from a dealer, it has a few cables that need removal so it is a little tricky, it is also a expensive part (approx Aus$200, why are you replacing it, are you sure you dont just need to clean feed rollers or there is also another common fault on these doc feeders, the left side hinge breaks( replace hinge)
here is the brother part number for the adf (complete), you will need to purchase from a autherised brother dealer -
LE8659001  DOCUMENT COVER LGL ASSY
Posted on Oct 17, 2007
SOURCE: Automatic document feeder doesn't wotk.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu06173&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en
please click on the above link to get the issue resolve
Posted on Oct 28, 2007
  • 58 Answers
SOURCE: Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
  • 15 Answers
SOURCE: Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Posted on Jun 09, 2009
  • 19 Answers
SOURCE: Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Posted on Jun 18, 2009
When I use the scanner, an unsightly thin black line appears on the right side every page. How do I get rid of that black line? Please help! Thanks.
Clean the adf scanner glass (the slit of glass on the left side). All it takes is one spot to cause a vertical line through page
Nov 16, 2015 | Canon PIXMA MX310 All-In-One Printer
I'm trying to fax with my Canon MX310, do the fax papers I'm sending go up or down? thanks
Documents need to be face down if you put them on the glass or face up if you have an ADF (automatic document feeder) for single sided pages.
When you put the document on the glass line up the upper right corner of the page (as looking at the back of the paper) with the marker at the left back corner of the glass. If you are using the ADF, put the paper in such that the bottom of the page goes into the ADF first.
I hope this helps.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Canon MX850 printer - ADF copy has black line on it
Hello, my name is Steve,.
This is a common problem and an easy fix.
If you lift the ADF / top cover assembly up, you will see a small narrow piece of glass next to the flat-bed glass.
Ths is called a "Slit-glass". The only purpose is to read content from that point by the scanner, The Scanner will sit in the underside of it.
It is dirty. Wipe this with glass cleaner and a soft lint-free cloth. you may need to do this several times. Concentrate the part of the glass were this image problem is just by the orientation of the document you are installing with the direction of the document you are passing through the ADF.
It will take several attempts, but with each try, make a new test from the original document, unyil the problem disappears.
I believe this will solve your problem, Best , Steve
Mar 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
Line on ADF feeder
Clean the narrow piece of glass inside the machine next to the large glass.
Oct 21, 2008 | Canon imageCLASS D860 All-In-One Laser...
Black line down paper
Please clean the scanner bed with clean cloth and then scan
May 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
Copier print quality
take a credit card and scrape the glass clean.  You only need to clean along the right side of the glass where the paper passes through.  Dirt that you can't even see will cause the lines.
Oct 04, 2007 | Canon imageCLASS D780 All-In-One Laser...
Canon imageCLASS D860 All-In-One Laser Printer Logo
44 people viewed this question
old marine
old marine
