Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
What is the oil/gas ratio for a 2-cycle engine?
    Sergeant:
  • 340 Answers
The ratio is 40:1 the greater being petrol
Posted on Oct 06, 2013
2 Suggested Answers
  • 64 Answers
SOURCE: engine quits
i run castrol 2 cycle oil. stihl oil is castrol oil as well. i use 40;1 in most of my 2 cycle equipment. i like it a little heavier knowing i am getting good lubrication to the motor. good grade of fresh fuel helps alot as well.
Posted on Feb 23, 2011
I have a craftsman lawn mower model # 917.387020 i need the oil to gas ratio
from what i see of the parts break down that is not a 2 cycle engine does it have a dip stick to check the oil?if so then is not a 2 cycle
Apr 27, 2012 | Garden
What is the oil to gas ratio on Poulan 3314
Poulan and Poulan Pro chainsaws with 2-cycle engines require a 40:1 gas-to-oil ratio, which corresponds to 3.2 ounces of oil per gallon of gasoline.
Jun 15, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
What is the oil gas ratio
The oil gas ratio is the proportionate amount of 2 stroke engine oil mixed with gasoline to be used as a fuel for the smaller (mostly) commonly used 2 cycle engines on chainsaws and weedtrimmers. Here is a oil gas ratio chart.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
May 17, 2011 | Garden
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the fuel gas ratio for a homelite yard broom ll 170mph blower
The mixture should be at a 50:1 ratio, using Premium Exact Mix™ 2-cycle engine oil. If Premium Exact Mix™ 2-cycle engine oil is not available, use a high quality 2-cycle engine oil, mixed at a 50:1 ratio.
You can get the manual on the link below if you need it also.
https://www.dixiesales.com/ipl/338/ut08120b%20manual_254_eng.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Homelite 'Yard Broom' Leaf Blower
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the ratio of oil and gas mixture for husqvarna 460 rancher
Find an Operators and an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel ratio 50:1 = 1gal premium/2.6oz quality 2-cycle engine oil
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
35 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
