Question about Fedders Heating & Cooling
Blower runs slowly if at all. Give it a spin or two by hand and it will slowly build up to full speed, RUN AND COOL AS NORMAL. But it only runs for a short time (12 to 15 minutes) then the blower slows down gradually then stops.
  • rudolph johnson jr Sep 02, 2010
    Sounds about right. Now how do I get to the motor/bearings? I already have the front plastic grill off exposing the foam filter and the cooling fins and tubing behind it. There are many screws in view and I don't want remove the wrong ones.
  • rudolph johnson jr Sep 04, 2010
    I just need to know how to get at the bearing, bushing, or sleeve to lube it to get me through the end of the summer season. I'll replace the entire unit when they go on sale in the fall (and probably for less than replacing or repairing the motor).
    Guru:
  • 642 Answers
The fan bearings have become gummed up and will need to be replaced or cleaned. I am assuming yours is not a split type. If so you will need to remove the whole unit from its casing. Have a look at this link :
http://dl.owneriq.net/2/2dca85dd-1381-4d1d-a2ed-08e8ffd24fe6.pdf
It is an installation manual and shows what to do to install/remove the unit.
Posted on Sep 04, 2010
  • 674 Answers
The problem will be either the capacitor for the motor or the motor itself. You can check the capacitor with a multimeter with the capacitor check function or take it to a heating and air supply and they can check it for you. If it looks swollen then it is bad. Does the fan spin freely by hand when the power is off. If not then it probably needs to be replaced. You can check the motor windings with an ohmmeter. I have dealt with a few where everthing seemed to check out but the motor was bad. Some problems won't show up until the motor gets hot.
Posted on Sep 03, 2010
  • Brian Niten Sep 03, 2010
    Most of the motors in window units don't have bearings but use a bushing or sleeve. Lubing might help for a little while but your best bet is to replace the motor.
  • Brian Niten Sep 05, 2010
    There may be hole to put a few drops of oil in on the ends of the motor near the shaft. If not, then there is no way to lube it unless you disassemble the motor.
  • 10,515 Answers
It seems to be a problem with blower motor. The bearings are seizing up when the motor is difficult to turn with power to it.
Generally, if the capacitor is bad, it won't turn at all or will quickly overheat and go out on internal overload.
If the motor feels "tight" when trying to spin it, the bearings are seizing and the motor will have to be replaced.
If there are oil ports, you might be able to spray some lubricant inside such as WD-40, but this does not always work and, if it does, it is only for a short time,but it might get you by if you need the A/C and cannot get it repaired immediately.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 02, 2010
Replaced bad blower motor and now motor will not run in a/c only in heat. I added a relay and wired for one speed to run in heat (tied into sequencer) and another speed in cool (off added relay). When...
You need to use a fan relay with one normally open and one normally closed contact. Run Hi speed (cool) through the normally open contact. Run Lo speed (heat) through the normally open contact of the sequencer and then through the normally closed contact of the fan relay. Make sure your thermostat isn't energizing the fan relay in heat and cool modes. If it is you can switch the heat option switch to Gas instead of electric on the back of the T'Stat and the fan relay will only energize in Cool mode
Nov 25, 2017 | Heating & Cooling
Whirlpool microwave fan not working
I would unplug the oven for 2 minutes to do a hard reset and try it again, just in cause there was a glitch.
Without knowing your full model number from the tag on the oven, I would wonder if it has a separate internal cooling fan from the hood vent exhaust fan. It could be an unrelated issue.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
Blower mtor on 1997 Chevy 1/2 ton 4wd runs real slow or not at all,some times it speeds up to near normal speed.
Yes, the blower motor is bad, replace it. This is exactly what you say, brushes are worn.
Dec 04, 2013 | Cars & Trucks
Our new colman mam 3 airconditioner vibrates loudly on hi cool could you tell us what could cause this please kind regards Dennis
I'd remove cover on roof and observe (carefully, with breaker shut off inside) blades on condenser fan as well as blower while spinning slowly first, and look for possible bent blade on rear fan blades, or even a mudwasp nest on either. If it happened immediately after installation, perhaps the small weights on blower wheel have come off, or shifted. At worse you may have a faulty or loose mount or bad bearing in fan. If it's been running good for a while, probably a nest has been added. Careful when taking cover off, for wasps, or yellow jackets under cover. If not obvious when spinning slowly by hand, stand back and have someone turn it on to see if you can determine where trouble is when running on high.
Aug 29, 2011 | Coleman Mach III Air Conditioner
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Jan 10, 2011 | Garden
Slow motor on lawnmowermower and smells hot
you may find that you have a build up of old cuttings under the blade impeller if they build up in the drive gear under the impeller then the motor will run slow do not try to use the unit as you will run the risk of the motor burning out fallow the user guide on how to clean and strip your unit down and please unplug it from the mains hope thi helps
Oct 22, 2009 | Electric Garden
Blower running on high only
most of the time these have a fan speed resistor in the cooling fan box under the dash there in there to keep them cool due to a lot of heat going through them when there on 1,2,3 and sometimes thay give up. the reason it runs on 4 is that its the highest setting and is getting the full 12 volts and does not run through the resistor. a replacment resistor should get all your speeds back
Apr 06, 2009 | 2001 Jeep Cherokee
Heating & Cooling Logo
62 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
