Question about Whirlpool LEQ9858P Electric Dryer
No heat.I checked the vents and everythign is clear. Is the heating element gone?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 04, 2010
Will not heat up
Basic instruction
Turn circuit breaker off thit can be checked for en back on, check dryer for heat.
If still no heat, (I am assuming that the dryer runs) There is a high temperature cut out on the heating element, it can be checked for continuity. the Heating element can also be checked. If this dose not help. I would need the brand and model number.
You should check the vent and make sure it is clear, I have had a lot of dryers that blow the fuse because of clogged vents.
Jun 20, 2015 | Dryers
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Dryer wont heat up
Most likely your heating element has gone bad. It will need to be replaced. Contact a qualified repair service. Hope this helps!
Mar 01, 2011 | Frigidaire FER231A Electric Dryer
Whirpool dryer 10 years old is still heating but taking very long to dry clothes. Checked dryer vent and it is clear. Will heating element help?
If your heating element is still heating up the cause lies elsewhere. Filter for dryer both at the base of dryer and filter location . If you are getting heat then airflow is the problem. how is the fan motor in front of heating element
Mar 09, 2010 | Whirlpool LER5636P Electric Dryer
My lint screen has no lint on it after drying a load. it also takes more than 1 cycle to dry. I have checked venting and it is clear. Heating element seems to be working, gets hot and goes off, comes back...
generically: Danger Will Rogers Danger...Better try to get inside the cabinet and check the venting....
..possibilities:
Vent pathway plugged (hence no lint) and lint backing up inside cutting flow and thermal sensor shutting down heating element.
..Vent hose in hole of cabinet but not connected to duct inside cabinet and lint is just filling cabinet. (common reason for premature heating element failure--3 times for my aunt fixed by tech--before I saw the vent hose connected only to the cabinet)
...both of the above is a hazard and can burn out the heating element.
..might possiblly be able to back blow through the vent hole and/or lint trap with a shopvac/vacuum cleaner (try **** and blow); but if works still need to verify that air pathways are clear and vent hose connected properly inside--should be fairly obvious inside.
...hope helps
Aug 09, 2009 | Roper RES7648E Dryer
I changed the thermal cutoff. it dried one load and then wouldnt heat again
check the thermo again, it might be going out due to a short in the element, or obstructed venting causing too much heat, clear venting or replace therm/heating element if needed.
Jun 30, 2009 | Dryers
Replaced element and now dryer too hot - vent is clear
Hi, Check the element again. It sounds like the element has relaxed and shorted out against the metal housing. The squeak might be the rear bearing cup. You can check and see if it needs grease while you have the drum out.
I hope this helps you. Please let me know.
Thanks
Vic
May 30, 2009 | Frigidaire GLER341A Electric Dryer
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
Dryer heats slowly
When dryer heats too slow, that means that there is a problem either with the heating element, the thermostat, or the vent.
See the following suggeations from Repairclinic:
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Oct 04, 2008 | Whirlpool Dryers
Whirlpool LEQ9858P Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
