Question about ASUS WL-330GE 802.11b/g Wireless Access Point
This is for the WL-330gE multifunction router. I want to set this up in repeater mode. The AP to which it will connect has WEP encryption and a MAC filter. When I use the simple set up for the WL, I can locate the AP and set that up as the default connection. My laptop can connect fine that way. However, I'd like to add some further protection to the repeater, by using its own MAC filter. This doesn't seem to work even when I give it both the laptop and AC MAC addresses. Oh, incidentally, I gave my AP the MAC address of the repeater as well. My laptop recognizes a good healthy signal from the repeater but has no internet connectivity. Please recommend what sort of security I can put on the WL in repeater mode. thank you!
  • 1 more comment
  • pdlevin Sep 02, 2010
    I attempted to have the encryption of the repeater set to that of the AP and also the set the MAC filtering to include only the laptop and the AP. The AP has the MAC addresses of both the laptop and the repeater in its list. I can't get the repeater to give internet access. I'm concerned that if I left the repeater without the mac filter, anyone could get in and access my AP. I'd like both security options in force unless the AP security alone would be sufficient. Please respond. Thanks.
  • pdlevin Sep 03, 2010
    DrifterK,
    Thanks much for the info....probably more than I can absorb (hey.....I started using computers with a card deck!! ). Anyway, I appear to have things working ok just with the password (as you suggested). My follow-up question is this:
    The AP (sorry....I meant access point, before) is a gateway with both LAN and wireless abilities. I'm using 128 bit WEB for encryption, and have mac filtering on for the wireless as well. This works just fine. As I mentioned, I added the repeater mac address to the mac list on the AP. Do I need to do this? When the repeater connects with the gateway, does it send its own mac address (so I need to enter that into the mac table) or does it simply repeat the packets from my laptop (which is already on the approved list)? If the latter, then it seems I can take the repeater mac address off the gateway list, and let that provide all the security. What do you suggest?
    Again, thanks much for your help!
    Best regards,
    pdl
  • pdlevin Sep 06, 2010
    I thank all the gurus for their advice. Unfortunately, none of the suggestions are helping me. I've sent an inquiry to Verizon (our SP) for suggestions on configuration or a different device to use instead. This is very frustrating, and to my mind, should not be all that hard to deal with.
    Again, thanks to all!
    Paul
    Master:
  • 515 Answers
Don't you need another router or something if you use this one as a repeater?
Posted on Sep 08, 2010
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then Click on wireless then wireless security enable WEP security then enter WEP code it is your password to connect wifi. Then enable MAC filtering and add mac address of computer where you want internet . Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 03, 2010
  • Yes you need to add mac address of repeater in allow list too.
    Because after all your laptop connects via repeater.
  • ASUS Master
  • 4,924 Answers
I think that you messed up when you set the MAC addresses ..the idea was if you have a static IP address..to set the Wlan first by choosing the static Ip ..and complete the ip ..sub net mask ..and default gateway ..just like in the TCP/ip protocol when you set the computer directly ..
If your provider have your initial computer's Mac address..(most have this protection on static IP addresses..) than you have to clone the mac of the router with the MAC of the computer that you made the setting with ..(I believe you call it AC ..probably from admin computer ) ..in such way your router will be seen on the network like it will be the initial computer with the initial LAN card that is registered to the provider..
in case of a non static one ...choose to obtain the IP addresses autobatically ..and clone the Mac with the AP one only if the provider requires for to recognize the right client ..if not ..it is not necessary ,,
IN case you have a DSL modem..things became more complicated cause even if the connection is like in the non static IP ..and its made auto ..you will have to change the IP of the router ..and so the ranges that will operate in ..order to provide Ip'es for the ports ..cause ...the router and the modem usually have the same IP address from factory ..and it will be a conflict ..and will not connect ..
so with a modem ..the Wlan will be ..the new IP address of the router ..the subnet mask ..255.255.255.0 and the modem became the default gateway ..and the servers are the same as was from the provider...
but when you will configure the ports ..the default gateway will be the router with the new IP ..the subnet masc will have 1 in the tail and the servers will be the modem IP ..
anyway I dont think is the case..cause I thing you have a optical cable connection ..but just in case..to have an idea..
so ..once the internet connection made...make the settings in the AC unit ..and connect it via one port to be sure you have internet connection ..yu can even try to connect it with the automatic IP in the TCP/IP protocol ..cause at this point the router should provide and IP and the rest of teh configuration ..but if you see something is not working ..choose user defined..and correct them manually ..
put the IP ..with one value in the tail more than the one of the router ..and the default gateway the IP of the router ..this for the first port ..and so on ..the next one will be with 2 units more in the tail digit ..ex..
router IP (in our case will be the default gateway too )
192.168.1.1
the first port IP will be ...
192.1681.2
and so on ..
the sub-net mask will be the same 255.255.255.0 cause it is a closed network ..
and the dns will be the ones that you used on direct connect ..or if you have a modem ..insert the modem's IP address..
after you did the connection on the lan ports ..go to wireless, and enable it ..and choose a middle channel from the 12 available ..than give it a name to recognize it in the network ..and it is enough to make a WEP encryption to insert a 13 characters password..cause only in a range of 100 m will be able to connect on your router ..and if you live on a house ..I dont think you need any protection cause most of them will be out of range ..
and a password is enough for the rest ..cause I don't think any hacker will get under your window to crack your network ..If you leave it without password..even if anyone connects to the network ..this will not affect your performance ..cause it is a parallel regime
In conclusion do not complicate things without a use..
another thing ..usually only one kinda protection will work at the time ..if you want to make them selected by the Mac address.its fine ..remove the password and make the access by selected and preset MAC addresses....but remember a mac address is much easier to clone ..(with a simple program free on internet or from the driver ) than a password of 13 characters to crack ..and if someone ever gets one of your mac addresses ..can easy connect ..but I dont think that a password..even simpler will be that easy to break ..specially cause the number of people with potential access is limited with the ones living in a 100 m area..
    Brigadier General:
  • 3,917 Answers
Hi
you must plug the WL-330gE into a device that has both a wireless connection and an active ethernet port. If the ethrnet port is active you should see two small lights on either side of the ethernet port on your device after the .WL-330gE is plugged in Once that's done you can run the detection software and it should find the device. Select configure and a browser will open and you'll be taken to the ASUS configuration website. Log in using the user name and password in the startup guide. If the configuration page opens up in diff language, select the drop down at the upper right corner of the screen and pick the first item in the list which is English. Select the tab which matches the configuration you need and follow the instructions.
Please check this link bellow regarding your query:-
http://www.ehow.com/how_2308651_use-router-as-repeater.html
http://support.asus.com/faq/asus-faq.aspx?no=A70012E2-9467-AAD5-D2AB-5B666D3C4A81&SLanguage=en-us
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 02, 2010
I use the Asus WL-330ge as a network adapter for my HP Printer. This worked perfectly until I switched internet providers. I changed the IP on my printer to the same subnet as my new wireless router...
Let me state how I think you have this setup
Printer is Ethernet ---------- Ethernet (WL-330GE wireless adapter)
WL-330GE adapter >>>>>> Wireless >>>>>> New Router
eth_adapter_mode-d2r1efs5ntrf2rjwzg4ldeyi-5-0.jpg Diagram and mode is from
https://www.asus.com/Networking/WL330gE/HelpDesk_Manual/
ASUS WL-330gE user's manual in English
So I think you need to use Ethernet Adapter Mode !
The computer shown would be your printer
As you are using wireless you need to set up the wireless ssid and the wpa or wep encryption to match the new router I am guessing .
in section 4.3 advanced settings in the above manual link from ASUS.
Also the access point has an ip address by default as 192.168.0.1 255.255.255.0 you would have to most likely have 176.16.1.2 and the new router as 176.16.1.1 and the same subnet mask what ever it is maybe it is 255.255.255.0 then make the printer 176.16.1.5 subnet 255.255.255.0 or whatever subnet you use.
Make sure you log into the new router and alter the DHCP server to assign leases from 176.16.1.10 to 176.16.1.254 with same subnet mask.
Mar 31, 2017 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Dear sirs, I need to re-config my Asus PORTABLE WIIRELESS ACESS POINT WL-330gE and is not possible to get the web page. I need to have a repeater and is impossible. I have a new modem NETGEAR wireless N...
You can reset all settings to their factory defaults manually by pushing the "Reset" button of the ASUS 802.11g AP while it is ON. Push the "Reset" button with a pen or a paper clip for about 5 seconds or until the power LED starts blinking.
Default
IP address: 192.168.1.220
username: admin
password: admin
May 07, 2011 | ASUS WL-330GE 802.11b/g Wireless Access...
I have set up this device as an AP and connected it to a adsl router, which also has another pc connected to it. I can connect my laptop to the AP and can even access the router, but am unable to browse...
Search in google about how to set up a DHCP server for your router and clone the modem's MAC address, most routers have this option, the thing is some ISPs limit the use of internet to only one machine, by cloning the modem's MAC address in your router you'll make the ISP believe there's only one machine connected to the Internet. By setting up a DHCP server in your router you'll use only one IP to connect all machines using a private network, that should solve your problems. Try both alternatives, and see which one works.
Please check the legal limitations of this procedure for your country or state and have a nice day! ;)
Apr 05, 2011 | ASUS WL-330GE 802.11b/g Wireless Access...
Cannot access 192.168.1.220 in web browser. Need it to set up WL-330GE as a repeater
If you have your asus WL-330GE connected to a router and you are trying to access it from another pc connected to the router...it will not work. You need to connect directly to the asus unit.
Then...
1)You will need to configure your computer to talk to it by changing the TCP/IPv4 under your LAN connection settings> Properties to read Manual IP of 192.168.1.10 if reset or 192.168.40.10 if not reset. then...
2) type 192.168.1.220 if you have reset it. Or 192.168.40.1 if it is not reset.
default user/pass is admin/admin for a reset unit.
Dec 29, 2010 | ASUS WL-330GE 802.11b/g Wireless Access...
Does the Symbol AP 3021 Access Point accept WPA encryption?
on the info i could find it only supports WEP.
but if your issue is to be more secure look up if it supports a sort of mac filter.
this will only keep everybody out of your router but your signal will only be WEP encrypted.
Feb 09, 2009 | Symbol Spectrum24 AP 3021 802.11b
Repeater function
you make a device into ap mode you can get it
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
CWA-854 as repeater
I couldn't manage to get the CWA-854 to work in repeater mode with WEP encryption enabled, but it is possible to use MAC Access Control even in repeater mode. Just put the CWA-854 in Access Point (AP) mode, add the MAC addresses you wish to allow in the Access Control tab and selecting Allow Listed from the pull-down menu, and then go back to the repeater configuration you posted. In this way, you may not have encryption, but you can still block others from connecting to your wireless network.
Jan 13, 2008 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
I can't connect to the router
Well since ur second computer goes online with wireless connection, so it seems the problem with your first computer.The only thing that you have to do is to update your wireless card drivers. Detailed answer: 1. Restart your computer in safe mode with networking mode. 2. Uninstall the wireless card. 3. Restart the computer and install the card again. This will definitely resolve your problem. Goodluck. ( Got the solution from ***)
Aug 27, 2006 | ASUS WIRELESS ROUTER |WL-520G - RT...
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
Encryption
The Access Point determines encryption. This is because the access point provides the path into the network. In infrastructure mode (all computers communicate through the access point) the AP is configured for 64- or 128-bit encryption. In 64-bit, WEP key 1 through 4 must be selected. In 128-bit, there is only one WEP key. The client computers must now be configured to the same WEP settings in order to connect to the network. If the WEP settings on a client are not correct, the client will show that it is connected to an access point, but no data can be exchanged, i.e.. no Internet browsing is possible, etc. 802.11b Ad-hoc differs only in that each computer must use identical WEP settings. There is no AP in the system to drive the WEP.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
ASUS WL-330GE  802.11b/g Wireless Access Point Logo
627 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
