Question about Toro Lawn Mower With Toro Power Tools
I have a Toro LX500, the Drive Pedal Spring broke off that controls the variable speed, I am unsure where the front of the spring connect to item#112-0308 the diagram from the parts catalog is unclear to me
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Posted on Nov 30, 2008
SOURCE: self propell just went out on my toro, how do I change the spring?
Can you please help, I am trying to put the belt on my toro and found that one of the bolt has broke off trying to fix it before husband gets home.ha I love all your help. Top on my list......
Posted on Jun 13, 2009
goldenglove1
  • 144 Answers
SOURCE: i have a toro lx500
Check the belt on top of the mower deck. Make sure the belt didn't slip off or break.
Posted on Aug 04, 2010
SOURCE: Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Posted on Mar 12, 2012
Clutch pedal sticks while in f/r.
brand/model number please... either a spring issue or a variable speed pulley issue
Aug 31, 2014 | Garden
Idle speed adjustment
You could also have an overused spring on the carb the connects to the govenor arm. Take the spring off and see how worn out it is.
Nov 06, 2013 | Toro Lawn Mower With Toro Power Tools
Toro personal pace lawnmower recoil spring broke
Go to www.youtube.com and type in fix starter spring lawnmower in Goggle.
Feb 28, 2012 | Toro Power Lawn Mower
I have a Huskee lawn tractor and as I was mowing the drive pedal stopped working. A spring broke and was still hanging so I know where one end a new spring will attach, but I do not know where the other...
Go to a website that sells parts for huskee you may have to go to mtd.com and find parts diagram for the deck, hopefully you can find your spring location.
Aug 04, 2017 | Garden
What is the drive belt adjustment 11.5 hp ride on mower
The drive belt is tensioned by a spring on the clutch pedal. If you can give me the model of mower you are working on, I can help you find the spring or the variable speed pully.
Thanks, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 15, 2011 | Mtd Garden
I have tension spring that is disconected inside a toro 824 snowb
That spring will attach itself to just about anything available. So put some hand tension on the idler pulley of the tensioner, and make an arc with the end of the spring, and there should a tab or bolt or post that the spring could attach to.
Aug 23, 2009 | Garden
BROKEN SPRING
Hi, check under your seat. at the frame there should be a bracket that the rod and spring goes thru and right to the pedal.
Nov 14, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
168 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
