Question about Calvin Klein K2227175 Watch
The ends have split and I need a replacement strap
  • 831 Answers
Thanks for contacting FixYa,
Hard one to find.
I would try this link and see if you find what you need.
http://www.bablas.co.uk/ck-watch-straps-c-38_39.html
Best wishes.
Jewel
Posted on Sep 03, 2010
The strap has split how can i get it repaired
Generally when a leather watch strap becomes damaged it has to be replaced. Seiko has a good customer service in the U.S. But you could try a shoe repair shop, they might be able to glue it back together.
Sep 21, 2010 | Seiko Sportura BAR Honda Racing F1...
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
My oakley detonator watch strap has split between holes,and also strap buckle.Where in uk can i get a new strap sent out to my home
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 23, 2010 | Oakley Detonator OAK0530 Wrist Watch
I am trying to remove a link from the strap to make the strap fit
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Mar 23, 2009 | Casio Watches
How to change battery in Casio wave ceptor4305
If there is no any screws holding that 'metal strap' then carefully check both ends of it. You will notice that the ends (or one end) are snaped over the little plastic hooks. Take pointed tweezers and push that end outwards (away from battery) and the contact (metal strap) will pop out.
After battery replacement, just push the contact back into place till it fixes.
If there are screws holding the contact, just undo them.
Be quick when replacing battery- you have 2 or 3 minutes to do that, otherwise all data will be lost and you will need to reset watch completely.
Dec 19, 2008 | Casio PRG-40T-7 Pathfinder
I would like to adjust my Pulsur watch strap but I cannot push those tiny screws on the strap
To do that you need a hardened steel pin and small hammer. Use that pin as a chisel and drive the bracelet pins out. Split pin end must come out first. When driving pins back in- blunt end goes in first and split end last.
You can make driving pin from hardened needle by blunting the pointed end.
Dec 17, 2008 | Watches
Fossil jr9339
I can only give a general guide.
Usually, watch bands can be shortened by removing links. These links are commonly held together by small pins. These need to be removed with a very fine punch. Looking at the ends of the pins, one end commonly appears "split", the other end may look quite smooth. The pin needs to be driven out from the "split" end. 2 will need to be removed to remove 1 link, then 1 replaced to rejoin.
Links should be removed equally, so gar as possible, from each side of the band. Your choice which side if 1 only is to be removed.
Sometimes the ending links are different to the others. It is only the ones that are identical that can be removed.
May 31, 2008 | Fossil Watches
Can't figure out how to change watch strap
Hi, try this - it worked for me. Use a needle to poke the ends of the watch strap axel (at the end and running across the strap). This should then allow you to lit the silver panels at the top and bottom of the watch face off. The axel should then slide out. I did this by pushing one end of it through with a needle so that the other end poked out enough to pull it out with a paid of pliers.
Feb 13, 2008 | Casio G-Shock G511-1AV Wrist Watch
Oakley band/strap
I called Oakley customer service and they said mail in watch and they will put on a replacement band for 45 bucks
Oct 28, 2007 | Oakley Detonator OAK0530 Wrist Watch
Calvin Klein K2227175 Watch Logo
233 people viewed this question
Top Calvin Klein Watches Experts
Joseph Hoffmann
aravind shet
aravind shet
Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
