Question about Samsung HP-T4254 42 in. Plasma Television
My Samsung flat screen takes a long time to show a picture on the screen and clicks the entire time. When the picture finally comes on, there are colored flecks on the screen.
  • 6 Answers
SOURCE: samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Posted on Sep 01, 2009
  • 59 Answers
SOURCE: 42 inch samsung lcd tv tv takes forever to come on
I would check the power supply for bad caps they will have a swollen top replace those and that should fix your problem
Posted on Jan 28, 2010
  • 21 Answers
SOURCE: Samsung 40inch LCD tv doesn't turn on for some
To all who are having power supply issues: Samsung is now acknowledging a problem with the faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Posted on Feb 22, 2010
freetek
  • 5568 Answers
SOURCE: i have a samsung model LNT4066fx ,series S303 its
The slow turn-on is normally a sign of a failing power supply and certain conditions could cause noise in the digital circuits of the set. The clicking is likely a relay that is controlled by PS circuits that are detecting a fault condition and repeatedly disconnecting the AC. The late turn-on will eventually turn into no power on at all.
Posted on Apr 04, 2010
budmrtn
  • 11361 Answers
SOURCE: Samsung 40
You may have dying power supply due to bad DC filter caps, look for caps with leaking/bulging tops, cold solder joints, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 15, 2010
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
I have a 60" lg
The time taken to show picture is due to leakage of electrolytic capacitors in the internal power supply of the set,if you are technical person check and replace the capacitors in the secondary stage of power supply,ti will suerly solve the problem.
Jan 22, 2011 | LG 60PC1D 60 in. Plasma Television
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
My Samsung 42" LCD used to turn on quickly, now it takes a LONG time for the screen to show anything. It looks like it turns on, turns off, turns on, etc. 7-8 times before finally staying on--almost like...
Ageing capacitors usually causes this sort of problem. They change value going low capacity etc. A replacement flourecent display board may likely fix it as the display is taking too long to come on.
Oct 16, 2010 | Samsung LN-T4081F Television
Hi I have a Samsung LE46M86BDX , and its beginning to take longer time beforer showing the picture, normally you can hear a "click" after 2-5 sec. and the picture shows, for a few days ago the "click"...
I had the same problem. http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related We're not alone - its a common problem with Samsung. I watched a few of these and was able to see the bad capacitors, de-soldered and replaced them for under $5.00.
Sep 01, 2010 | Samsung 32 in. LCD Monitor TV
Samsung tv turn on problem
Aug 23, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung SP-S4223 42in. EDTV.
This is called tiling and this happends because of a weak signal from whatever device you have hooked to it weather it be cable or a sat dish. Try checking and makie sure you have good signal to this. If this matter gets wrose then you would need a repairman. Thanks
May 24, 2009 | Samsung SP-S4223 42 in. Plasma EDTV
Samsung HP-T4254 42 in. Plasma Television Logo
250 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
