Question about Jobar International Ideaworks Remote Read Digital Scale
I have a 550 lb large capacity bath scale. It does not weigh. The hand held has info on it. Is the scale part supposed to have a light where the infared thing is?
5 Suggested Answers
SOURCE: Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Posted on Nov 20, 2008
  • 279 Answers
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Posted on Jan 17, 2010
Dane1234
  • 25 Answers
SOURCE: Just purchased the Ideaworks Large Capacity Bath
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Posted on May 15, 2011
  • 500 Answers
SOURCE: when set on lb,pounds, scale
Hi dogwalk564,
Make sure of the following:
Be sure to place the luggage in the dead center of the scale, this will distribute weight evenly across the scale, also try to keep it on a level floor, any slight incline or decline to a side of the scale, will give you a bad reading.
How do you know the scale is incorrect, how do you reference it to the current reading?
Kind Regards
JEDMEEYER1
* If this solution helped, please accept it
Posted on Aug 08, 2011
Digi weigh scale (hand held) powers on, then reads "LLL". Will not cycle thru calibration correctly . Can it be fixed?
Remove and refit the battery. this may reset it, if not replace it as the cost of repair will be more than a new one.
Sep 03, 2016 | Health & Beauty
What does Err H mean?
That means that something heavy was weighed and now it is out of calibration.
May 24, 2016 | Taylor 3801 11-LB CAPACITY DIGITAL KITCHEN...
My scales show 3.5 kg lighter than actual reading. What can I do?
check at the back of the scales for an adjustment screw or knob
to make the adjustment you will need items of known fixed mass over say 2 lb to 40 lb
you can do this by accurately measuring 1/2 gallon , 1 gallon 2 gallon 4ga;;ons of water as it is 10 lb to the gallon
there may be a pdf version download on the net if you go google and type in--- user manual for (make and model ) scales
May 05, 2016 | Health & Beauty
Long sleeve shirt why did you weigh scale reads 0 - LD what's that mean
Are you sure it wasn't 'lb', which is Latin for pounds?
Mar 26, 2016 | Health & Beauty
Envelope postal scales by pelouse
go to a tobacco shop or a tobacco pipe shop"head shop",or ebay, Vintage Pocket Hand Held Postal Scale 0 2oz ,or here, Postal Scales Hand Held Scales , or, Items found similar to Hand held pocket postal scale keychain 100 grams... good luck,most staples will not sell them because they are commonly used to weigh drugs.
May 21, 2014 | RTO Pelouze Scale With Remote Display -...
Escali scale wont turn on
Step on the scale and immediately step OFF and the scale will then be ready to weigh you. If this does not work, then you need to replace the battery.
Apr 05, 2013 | Escali BFBW200 Body Fat/Water Bath Scale
How switch the unit?
sometimes depending on the scale you have if there is not a units key you have to turn the power off, then while holding one of the other keys down, turn the power on and the units will change. if something else comes up that doesn't make sense just power the scale off and when you turn it back on it will be back in weigh mode
Mar 09, 2010 | Health & Beauty
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Fat reading accuracy problem
You must not be dehydrated - do not use first thing in the morning or immediately after a workout or after consuming alcohol. Use 3 hours after a meal and after voiding your bladder. Women may experience fluctuations with retaining water, and those on diuretics may see inaccurate readings. You need to weigh yourself without clothes.
Aug 27, 2008 | Detecto 6475 Digital Chair Scale, 400 Lb...
Jobar International Ideaworks Remote Read Digital Scale Logo
81 people viewed this question
Top Jobar International Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jobar International Health and Beauty Expert? Answer questions, earn points and help others
