WHEN DRYER STARTS IT WILL RUN FOR A LITTLE WHILE AND SHUT OFF. YOU WON "T BE ABLE TO START IT FOR A LITTLE WHILE. AND WHEN IT STARTS AGAIN IT WILL WORK SOMETIMES.
Re: WHEN DRYER STARTS IT WILL RUN FOR A LITTLE WHILE AND...
There is a protection device called a thermal control it could be ovreheating because of an internal clogg or thermal fues located in rear or the heating elements and also check lent trap, check this first
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Test air flow. Remove the exhaust hose at the rear of the dryer, run the dryer and form an opinion on the volume of air flow, hook the hose back up, turn on dryer again and verify that the same volume of air exits the building. Usually a build up is the cause of your complaint.
