Question about Eureka 6282249 Adventure 2 Person Tetragon 5 Tent
Borrowed a Eureka, Moon River 2 tent with fly, and can't figure out how to set it up. There are 2, 10' (?) collapsable poles. A pic of one set up would likely help.
4 Suggested Answers
SOURCE: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Posted on Aug 25, 2009
rcalorisian
  • 313 Answers
SOURCE: what problems have been reported on the eureka tunderline tent
It seems like a pretty good tent good reviews from thebackpacker magazine which I subscribe to for my gear. Every one says is ia a great tent, not built like it used to be, but a great buy.
  1. TheBackPacker.com Reviews: http://www.thebackpacker.com/gear/tents/eureka_timberline.php
  2. Cabela's customer reviews: http://www.cabelas.com/p-0003796510396a.shtml#customer-product-reviews
  3. Amazon customers reviews: http://www.amazon.com/Eureka-Timberline-Adventure-7-Foot-Two-Person/product-reviews/B000EQ813S/ref=sr_1_21_cm_cr_acr_img?ie=UTF8&showViewpoints=1
I hope this has helped you. let me know..
Posted on Sep 09, 2009
  • 75 Answers
SOURCE: I need a complete set of poles for my timberline 4
Not sure how much they cost. If the elastic is gone, you can replace elastic line and this should be a cheaper alternative, if the poles are broken, then you'll probably need to replace all.
Posted on Nov 10, 2009
I need instructions for 89034 17x15 moab
Instructions
  1. Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
  2. Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
  3. Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
  4. Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
  5. Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
  6. Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
  7. Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Read more : http://www.ehow.com/how_8092535_directions-ridgeway-tent-kelty.html
Jul 23, 2015 | Baby Gear
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
    I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
    Paul.
    Dec 23, 2010 | Sport & Outdoor - Others
    Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
    I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
    May 19, 2010 | Toys
    Square tent with 2 types gazebo poles, varenda, 2 side windows
    the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
    shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
    May 04, 2010 | Wenzel 18'x10' Sycamore 3 Room Tent
    I need a complete set of poles for my timberline 4 tent, how much do they cost?
    Nov 10, 2009 | Eureka Timberline 4 A Frame Tent
    Swiss Gear Tent - Broken Poles SG33071F
    Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
    Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
    Jul 25, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
    Eureka 6282249 Adventure 2 Person Tetragon 5 Tent Logo
    214 people viewed this question
    Top Eureka Sport & Outdoor - Others Experts
    Are you an Eureka Sport and Outdoor - Other Expert? Answer questions, earn points and help others
