Question about Kodak EasyShare Z612 Digital Camera
Camara lens is stuck .it turn off two seconds after i turn it on
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 02, 2010
When i turn my camara it tell me.... please turn camara off and then on again.. so i do it and it tell me the same thing i dont know what to do or were to take it
It seems your camera's Battery is not holding a charge, you need to replace it with another one.
Also this issue usually comes due to the lens getting stuck and is unable to come out, so please try charging your battery and check for any dust/foreign material stuck in the lens preventing it to come out properly.
If the problem still persists, take your camera to an authorised service centre.
Good luck
Mar 16, 2010 | Panasonic Lumix DMC-FZ30 Digital Camera
The lens gets stuck
This happen to me also. I heard a rattle before the lens got stuck. So I loosed some of the screws on the side of the camara and opened the case slowly and carefully. A small screw fell out and the camara has worked fine since (about 6 months). You may have an internal screw that is jamming the lens mechanism.
Oct 05, 2009 | Fuji FinePix 2650 Digital Camera
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
My l200 camara lens is stuck
huSh now :( I remember my former camera.. XD
Lens errors are fairly common. Usually it's sand or grit interferingwith the lens extension mechanism. Or the camera's been dropped withthe lens extended. Or the camera has been powered on, but the lens hadbeen blocked preventing its extension. Or the battery ran down with thelens extended ...
Here's some things that you can do to try to correct it. They only seemto work for less than 50% of the lens errors, but if the camera is outof warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12...
hope this will help ya out
Jun 06, 2009 | Samsung L200 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Problem with camara
Lens isn't working and need to be replaced.
Jun 07, 2008 | Cameras
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Lens problem
If you've replaced the batteries with fresh ones, it probably has a broken zoom assembly. It'll have to be replaced by a repair shop.
Dec 13, 2006 | Canon PowerShot A520 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
54 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
