Question about Whirlpool Refrigerators
Whirlpool Freezer on top Refrigrator - White-on-White Ser. VSU4609729 Model: ET0MSRXTQ00 Type 10' TFA - 9.6 cu.ft Mfg. Dat. 11-07 Problem: 1) Freezer on top is in good condition but Refrigerator is always warm and Compresor run always. 2) This Refrigrator is in warranty or Not and I should pay for labor fee & parts if necessory? Thank you for your considration
fridgetech
  • 473 Answers
SOURCE: Kenmore 65092 Refrigerator
This fan will be running anytime the compressor is running. If it isn't then it has failed and will need to be replaced.
Posted on Nov 12, 2007
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
  • 378 Answers
SOURCE: Compresor will not kick on. all fans running,
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
Posted on Apr 03, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
tomsat69
  • 219 Answers
SOURCE: My Whirlpool 21. cu. ft top freezer drips water
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Posted on Mar 17, 2010
Hi, In my refrigrator there is no water and ice coming.and i dont find where is the fiter.my refrigrator type is 2255a mod # ed2choxkb07 ser,# issu4235315.thanks
Since you did not provide a model number this is the best guess. On 25 Cu Ft and above models no matter the manufacturer most of the filters are in the left portion of the grille at floor level. You turn the tab and the filter pops free. If yours is not in this are just respond here with a model number and I will help you.
Kelly
Oct 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer of the refrigrator is not freezing. Norge,
sounds like the cold coil is freezing up and this is a defrost problem.. ck the defrost themo/ and the heater . / may also be the defrost timer . but every 3 mo ( i would think the defrost terminator is failing .. ) mm
Aug 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leak inside and outside of refrigrator
Hi, it is worth fixing. There is a drain plugged in the freezer. Get me model # and I can assist you further on this matter.
Thanks
Vic
May 22, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Foul odor coming from freezer. Kenmore model w/ freezer on top.
Clean the refrigerator thoroughly fresh food and freezer under all drawers. Then place charcoal briquettes in each 8 or 10 total. 4 or 5 in the bottom of the fresh food section. leave the for several days. If that doesnt take away the smell consider if a mouse may have gotten into a fan blade and well that can create a really bad smell.
Jan 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
230 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
