Question about Dell Inspiron 630M Notebook
Dell Inspiron 630m HDD upgrade. BIOS does not allow!
I tried to upgrade the 60GB IDE (original disk) with a 250GB IDE disk. The BIOS does not allow me to change the original factory setting of 58GB HDD in the System INFO. BIOS states, "These Parameters cannot be changed."
I have had the laptop from new, and I have not set any BIOS password protections. Any suggestions as to how to change the BIOS settings for HDD size?
Thanks.
KM
  • Anonymous Apr 06, 2009
    Inspiron 630m can't read 250g drive in bios and windows =/
    My inspiron 630m does not read my new 250g hard drive in the bios or windows
After much searching on the web for many unhelpful answers, I finally discovered what the actual issue is, so then I was able to fix it. I will be posting this in as many places as possible so that future people having this issue won't have to struggle with it for hours like I did.
First of all, as much as I love Samsung drives, avoid them for this model. There is some sort of "brain-dead incompatibility" (as one guy put it) that prevents them from working correctly. Western Digital costs more and is slower, but it at least will work correctly in this unit.
The size issue is not the BIOS at all. I discovered this by accident. The issue is that Dell's software engineers are stupid......or at least were. Dell customized the boot loader in the MBR, which gives the www.dell.com bar upon bootup. The issue is that this is not the only thing this weird bit of code does. Programmed into this odd bit of code is the size of the original hard drive. Upon executing, this boot code then sets the hard drive HPA to that size. For people unfamiliar with HPA, it tells the hard drive what size it should report itself to be. If you had put the hard drive in the machine blank, you'd see that the BIOS correctly reported its size. However, once you clone the old hard drive onto it and boot it, that funky MBR writes an HPA to the drive, telling it to report the old size, which it dutifully does.
The solution is as follows:
1. Remove the HPA with a utility like MHDD (Maysoft's Hard Disk Utility), which can be downloaded as a bootable CD. Other utilities provide this functionality, but I am most familiar with MHDD's implementation. Once you boot MHDD and select the drive, type "hpa" to launch the HPA utility. It will show you the native maximum addressable LBA, which you will then tell it to apply persistently (1), type in the native address, and confirm with y. It will say "done."
2. Reboot, but this time boot from the Windows XP CD. DO press a key to boot from the CD, when prompted. After it loads the text-mode Windows, select "R" to repair with the recovery console. Select your preferred keyboard layout if it isn't US, and select the Windows partition to log onto by number. You will need to know the Administrator password for the Windows installation. On many of these units there is none; simply press enter when prompted on these machines. If you don't know what it is, NTPASSWD is a great utility to clear them--do your own research on that one. Once you are logged in, type "fixmbr" then "fixboot" to replace Dell's weird bootloader with the standard Microsoft one. You will get a warning that the computer has a non-standard or invalid MBR......which we already knew, so tell it to go ahead and fix it. In spite of its dire predictions, I have never had fixmbr lose partitions, no matter how non-standard the MBR may be.
3. If you adjusted the partition smaller to make Windows boot, you can now expand it to fill the hard drive. Windows will boot normally, without that Dell bar or a BSOD.
If this helps you, please consider making a small donation to business [at} silverdollarsolutions.com via PayPal. I put in a lot of time solving this issue and writing it up, and it would be nice if people would chip in a little if this has been helpful to you.
Posted on Mar 27, 2012
  • 191 Answers
I need your system's service tag . its located at the bottom panel of your laotop.its a 7 digit alpha numeric numberwe will have to update BIOS.
or else you log on to http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
punchin your service tag
you will get list of drivers
there would be an option which says BIOS
download that update and run it
make sure your battery is in and ac adapter is connected
and do make sure you have the right windows selected , you will get these option just above the drivers list
Posted on Jun 05, 2008
Dell bios password for 630m inspiron service tag # GWMYN91
You could try here:
BIOS Master Password Generator for Laptops
Or this application:
Dogbert Blog
The second is probably more likely to work, as long as the serial ends in -2A7B or -595B.
Jan 15, 2014 | Dell Inspiron 630M Notebook
Bios passwords dell inspiron 630m
You could try here:
Dogbert Blog
Hi, when I tried to upgrade/clone existing 60GB HD in Dell Inspiron 630m to HM160HC Samsung HDD, the HM160HC was partitioned to 60GB. I tried to fix the LBA to get back 160G but no success. I think only...
Hello Private672, Hi, If you have no important documents on the HDD or has been back up already, the full hdd size can be edited when you install another windows on it. there is a portion in the installation where you can delete and edit the partition. There are other free software utility on the internet for downloads to edit and low level your hard drive to get back the full size. among these are Partition Magic, Disk Manager. do a google search
Mar 02, 2011 | Samsung SA07HM160HC Samsung HM160HC 2.5...
What is the maximum Hard Drive upgrade posible for Dell inspiron 630M?
Your BIOS will only see 137 GB. at a time. I installed a 320 gb. but I had to partition it into 130 gb and 190 gb.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 19, 2011 | Dell Inspiron 630M Notebook
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
I have a laptop Toshiba Satellite A75-S206 Intel Pentium 4 2.8GHz / 802.11b-g Wireless / 15.4-inch WXGA / 512MB DDR / 60GB HDD / DVD-ROM/CD-RW Combo / and I want to change the hard disk.I want a list with...
That takes an IDE HDD. They are universal so any notebook IDE HDD will replace that 1. I like Weatern Digital because they really are good about standing behind their hard drives. Now it only came with a 4200 RPM so when u upgrade purchase the 5400 RPM. If the bios firmware only supports the 60GB then u will need to format a larger drive with a second partition using admin tools as a mass storage device.
Aug 14, 2010 | Toshiba Satellite A75-S206 Notebook
WHAT TYPE OF HDD USEINGTHESE DELL INSPIRION 630M
In most casses it is an IDE remember to keep the harddisk connector when removing the old one.
Jan 27, 2010 | Dell Inspiron 630M Notebook
HDD wont fit!!
Just looked at the details that are stored on fixya, I see the laptop would have a SATA connector, so the new one is IDE? you will have to get a SATA drive and it should fit. well compair the original to the new one, the one with flat connectors fits?
Jun 15, 2009 | Dell Inspiron 1521 Notebook
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
Dell Inspiron 630M Notebook Logo
987 people viewed this question
Alun Cox
