Question about Cameras
My canon 450d when i push the shuter botton it sayscard write proctected and will not take poto
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 03, 2010
What is the latest firmware for canon 450d?
1.1.0 and this site from Canon, you can download the firmware.
Canon EOS REBEL XSi 450D Firmware Download
Only when you have a new lens, not yet supported by your came, I would get the firmware.
Jul 26, 2014 | Canon EOS 450D Digital Camera
Error code 001 with canon 450d
Seems a lot of people are having the same problem. Take the lens off the camera and clean the little gold contacts (metal squares) on both the lens and the body with isopropyl alcohol or pre-moistened len wipes.
Mar 21, 2013 | Canon EOS 450D Digital Camera
Which would you recomend i buy 450d or 40d
You can compare these two products from the web site below:
http://www.dpnotes.com/canon-40d-vs-canon-450d-digital-rebel-xsi/
good luck and do rate the solution if helps
Dec 07, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 450d not clicking on AF mode
this may have to do with the lens rather than the camera, try swapping the lens with another one and see if the same problem happens in AF mode with the new, borrowed lens, also remove lens and check that the gold connector between the two are clean carefully wipe with a dry q tip but be careful not to allow dirt to fall into camera body.
Apr 12, 2010 | Canon EOS 450D Digital Camera
Setup canon 450d remote control
There should be no set-up process. Plug in the receiver to the socket under the rubberised flap on the left side of the body, extend any ariel on the release itself, make sure any switches are on and away you go. There may be additional channels on the set in case you have interference from other wireless release users in your vicinity.
Mar 03, 2010 | Canon EOS 450D Digital Camera
How to replace cr2016 from 450d/XSi or 500D/Xt1
The other bloke doesn't know what he is talking about..this is plainly obvious.
Looks like the CR2016 is inside the battery compartment under a small cut-out plastic piece (on same side as hinge). Use a torch and you can see it under this plastic piece.
You either need to dissemble it to get access or break off this plastic cover to replace...or take it to canon.
Dec 22, 2009 | Canon EOS 450D / Digital Rebel XSi Body...
Compatibility of cullman cx35 with canon 450D
It shouldn't hurt the 450D: you won't be able to use TTL mode.
Aug 21, 2009 | Cameras
My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
May 16, 2009 | Canon EOS 450D Digital Camera
Colourwash on 450d
The sigma lens must be reprogrammed especialy for the EOS450D... series You must contact Sigma and not Canon it's not their problem
Regards
Rob NL
Apr 16, 2009 | Canon EOS 450D Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
