My Whirlpool Top Load washer cleans the clothes, spins, drains and then as soon as its done spinning it begins to fill up again as if I started a new load. It fill up about 6 inches of water and then stops. Then it stays like that. Any help?
  • april022ca Sep 02, 2010
    The machine has never overflowed and its actually sprays water after the spin cycle as if it were starting a new load but only fills part way and then stops. Could these solutions still work??
  • 11,896 Answers
I believe the timer is faulty, it is skipping the off position, going to the first cycle, then stops thinking that is the off position.
Posted on Sep 03, 2010
    Brigadier General:
  • 3,917 Answers
Hi
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch .
A defect--or an obstruction-in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 02, 2010
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
My daughter has a new Whirlpool WTW4800XQ0, it takes the machine about 3 hours to go through the cycle. Okay this being said, when it gets to the spin cycle, it doesn't, she is having to pull the...
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
Washer starts agitation during water fill up and after spin cycle ends washer fills back with water and leaves clothes very wet.
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Oct 20, 2010 | Whirlpool WTW5850S Top Load Washer
New calypso today. when the clothes are done the are soaking wet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
