Question about Brother MFC-5460CN InkJet Printer
This printer is new to me MFC 5460cn. I have the cartridges but cannot figure out where to put them.
  • 8,197 Answers
On the link below is the manual on page 8-9 tells you how to install the ink.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002150/BHL7_UkEngQsg_A.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 02, 2010
MFC-5460CN printer, asking for ink, replaced cartridges, now still saying no ink and replace cartridge...
Main problem with Inkjet Printer cartridge is, ink gets dry after no use for long time. In your case, your cartridge provider might be given you out dated cartridge or if not, there may be technical problem with your printer.
Jul 18, 2014 | Brother MFC-5460CN All-In-One InkJet...
Printer will acknowledge only 3 of 4 new ink cartridges - keeps saying change LC51M
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
Sep 17, 2012 | Brother MFC-5460CN InkJet Printer
Machine says that magenta is empty, cartridge level reads empty. But when I put a new magenta cartridge in it reads no cartridge open cover and reinstall magenta cartridge. The cartridge is full and is a...
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Sep 28, 2009 | Brother MFC-5460CN All-In-One InkJet...
How do I change the ink for the Brother MFC-5460CN all in one printe?
you can replace new catridge instead of reffiling. you will find better performance.
Aug 21, 2009 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-5460CN won't scan because cyan ink empty
Brother is telling us that sometimes the cartridge can be installed too fast causing it not to read. Install it slowly to see if that helps. Also, power down, remove all the inks and power up. Add the inks one at a time when it asks.
Jul 09, 2009 | Brother MFC-5460CN All-In-One InkJet...
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Printer
My Brother MFC-5460CN printer is doing the same thing. I installed a new black cartridge (I have it set to default greyscale) from a different company and it worked fine the first four or five days, but then it started printing light again.
Jul 22, 2008 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 5460CN No cartridge error
The tape method worked for me on my 1960C. I put duct tape over the window in the front. If there's a place you can see ink, cover it up.
Nov 14, 2007 | Brother MFC-5460CN All-In-One InkJet...
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5460CN InkJet Printer Logo
90 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
