Question about SanDisk 2GB Secure Digital Memory Card
New Card Locked
I just bought brand new SanDisk 2GB memory card. Put it in the camera and it says it's locked. Never used. Now what?
  • Gooz May 11, 2008
    You are the best!!! I am not too camera savvy and didn't even know you could lock a disk. Thanks. You saved me.
Check to see if the locking slide on the side has been accidentally pushed: one of my new ones was like this.
Posted on May 11, 2008
Have you tried to format it with the camera? It may need formatting in order to unlock it.
Posted on May 10, 2008
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
I just bought a new sd 2mb sandisk card but computer won't detect it
Are you using a Memory Card adapter? Or are you using the SD slots that are built into your computer?
Go to the 'Start' menu and choose "My Computer"
The card should be there, if not, then make sure that the little 'lock' button isn't set to lock.
A lot of times when you insert the card, it will switch the position from unlocked to locked.
Good luck
Jan 21, 2011 | SanDisk 2GB microSD Memory Card
I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
HP Photosmart R967 memory card is locked...
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
Sep 12, 2009 | HP Photosmart R927 Digital Camera
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
Memory Card
make sure that the memory card you bought is a secure digital (SD) memory card. the kodak memory you have might not be an SD card.
Aug 25, 2008 | Vivitar ViviCam 3785 Digital Camera
Locked memory card
I guess it is a simple switch problem..
try to switching it between lock and unlock many times until it become ok again..
If it will still not unlock itself, try to format it, for some errors to erased and starts a new one.
Jan 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Computer doesn't recogize my SanDisk 2GB Memory Card
you could try downloading directly from the camera, using the appropriate USB lead, if the camera can see it it should be able to download via cable.
Oct 22, 2007 | SanDisk Memory Media
SanDisk 2GB Secure Digital Memory Card Logo
105 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
