How i now my router?
Help to find my router brand
  • 6,487 Answers
Check on the front panel of the router or look for a sticker on it or just look for the model number and after that check it in google.com.
Posted on May 10, 2008
Bought a new router and now can't connect to water timer through wifi.
Are you getting a particular error? If you can provide information on your router it would be helpful. Particularly the brand/model of the router and the brand/model of your water timer. Thank you!
Jun 08, 2016 | Hardware & Accessories
Error 52030. Unable rto connect to internet
Hi
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
  1. Don't know how to find your router's security key? Let us help! Select the brand of your router below and we'll show you how to access your router's settings. Linksys Netgear DLink Belkin Apple 2Wire All other brands
      Once you have entered the correct WEP or WPA key into your system, try the connection test again. If the problem persists, keep reading this page.
    Additional information:
    • Using an Actiontec or 2Wire router? The default security key is often found on a sticker located on the router.
    • Security keys are case-sensitive.
    • WEP keys contain numbers 0 through 9, and only letters A through F.
  2. Manually assign an IP address to your Wii console.
      Assigning an IP address to your Wii is easy!
    1. Access the Wii System settings and select "Internet" from Page 2.
    2. Select "Connection Settings" and choose the connection file you currently use (will have a red border around it).
    3. Select "Change Settings," and click the right blue arrow twice to reach "Auto-Obtain IP Address."
    4. Click on "No" and select "Advanced Settings."
    5. Now, click in the "IP Address" field to enter an IP address. Look at the brand of your router, and enter the IP address listed below into the field.
      • Linksys - enter: 192.168.001.140
      • Netgear - enter: 192.168.001.250
      • Belkin - enter: 192.168.002.090
      • D-Link - enter: 192.168.000.190
      • Apple - enter: 010.000.001.250
      • 2Wire - enter: 192.168.001.250
      • Actiontec - enter: 192.168.001.250
      • SMC Networks - enter: 192.168.002.190
      • Don't see your router brand listed? Click here for help with finding an IP address to enter.
    6. Once the IP address is entered, select "OK."
    7. Select the Subnet Mask box, then enter 255.255.255.0 and select "OK."
    8. Select the Default Router box. You will need to enter the defail gateway address for your router brand. Look at the brand of your router, and enter the gateway address listed below into the field.
      • Linksys - enter: 192.168.001.001
      • Netgear - enter: 192.168.001.001
      • Belkin - enter: 192.168.002.001
      • D-Link - enter: 192.168.000.001
      • Apple - enter: 010.000.001.253
      • 2Wire - enter: 192.168.001.254
      • Actiontec - enter: 192.168.001.001
      • SMC Networks - enter: 192.168.002.001
    9. Select "Confirm" but DO NOT select "Save."
    10. Tap the right arrow to reach the page ro "Auto Obtain DNS."
    11. Select "No" and then "Advanced Settings."
    12. Click into the "Primary DNS" field and enter: 008.008.008.008
    13. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    14. Select "Confirm," and then "Save."
    15. Click on "Save" and then "OK" to perform a connection test.
    16. If the test was successful, then your Wii is now connected online. If you received error code 52130, please call 1-800-255-3700 so that we may assist you further.
  3. Other suggestions:
    • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
    • The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again (steps), but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different, try a "Manual Setup."
    • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
Jul 29, 2011 | Computers & Internet
How to access this kind of brand of router? its my project in school can you help me..who is the inventor of this brand?
Linksys, is a brand of home and small office networking products now produced by Cisco Systems, though once a separate company founded in 1995 before being acquired by Cisco in 2003. There is a full history on Wiki (here) http://en.wikipedia.org/wiki/Linksys
To access the device, the computer must be connected to the router with an ethernet cable (not over WiFi.) Open a web browser such as Internet Explorer. Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter]. A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Linksys Wireless-G WRT54GS Router...
What brand compatible wireless router for the laptop
Any brand of wireless router will work with this laptop , but as a suggestion you can go choose from this brands of routers Linksys , Netgear , Belkin and Dlink any of those will be a good choice of router to get.
Nov 18, 2010 | HP Compaq Evo n610c Notebook
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
Wep passphrase
You will be able to get the wep key or passphrase from the wireless router or access point.
To some routers, the SSID (wireless network name) and WEP keys are found underneath the router itself. It you cannot see any, then you will need to access the setup page of the router.
This depends on what is the brand of your router.
If you let me know the brand and model I might be able to help you in checking the settings.
Oct 25, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Wireless router
First, What the brand and model of the router?
Try this:
1 - Click in the RESET button.
2 - Access the Router via Browser and check if the router are totaly OK.
3 - Power Off and Unplug the Wall, reconect with 1 minute out.
But more help, you may send the brand and model.
Bruno Gamba
Jul 22, 2008 | Computers & Internet
I have wireless router and my laptop will no longer connect to the internet. The computer says wireless networks are available, but when I try to connect it asks me for my security key or passphrase. It's...
Maybe provide the brand of router.. Anyway, I have lost my details as well, several times over the last couple of years.. It's just a case of accessing the router (via web browser, using the correct IP address for your brand of router).. Then you can delete the existing network & add a complete new one. You get to use a new key & passphrase. If you need further help, please provide your router brand & model. Rgds, dave
May 02, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
