Question about Toshiba Satellite A65-S126 Notebook
Atheros Wireless connect problems
Im trying to get on the internet using the wireless (It is switched on). When i double click the wireless connection icon in the tray, the screen comes up and says that i have at least 3 wireless networks available, including the one i have hooked up to my pc which serves my hp laptop. i type in the same network key i used to get my hp up and running, hit connect, and nothing happens. the screen drops, but there are no prompts, no error displays, nothing. i go back to the tray to check if i am connected, and it says 'one or more wireless connections are available.' ive also gone into the advanced menu on the wireless network connection screen, and have tried to configure my network using the info i got from my d-link router software, and that does nothing either, no errors, nothing. when i go and check my network connections through the start menu, under wireless network connections, it says 'wireless connection unavailable.'
What do i do?
  • 37 Answers
Your wireless devices are not configure to the right value. Start the wireless network wizard in your desktop computer.(Start- Control Panel - Network and Internet Connections - Setup a wireless network for a home or small office) Follow the on-screen instructions. After finishing, run the wizard in the router and then run it in the devices that you want to connect to the network.
Posted on May 10, 2008
Compaq laptop will not connect to my netgear N300
Try switching the way you connect the wireless. On your laptop there are 2 different ways to connect, one using the the client application that goes with the wireless card, and the other way uses windows to manage and connect to the wireless. Switch them out. If you are using Windows, then use the other or vice versa. Open the software that came with your wireless card it should be on your desktop or in your program list. Click Start/Programs and look for it. For example it might be something like Atheros. Open it and look for a place or check mark on something that says: Let This tool Manage the Wireless, or Use Windows Zero Config to Manage the Wireless.
Apr 25, 2012 | Computers & Internet
I recently replaced my old Belkin N150 Wireless Router with a new Cisco E3200 Wireless Router. After doing so, all of my wireless devices work (9 total) EXCEPT for my (2) Acer Aspire One Netbooks. The...
Remove and recreate the wireless network connection
  1. Click on Start, and then Control Panel
  2. Double click on Network Connections
  3. Right-click the wireless network connection, and click Properties
  4. Click the Wireless Networks tab
  5. Under Preferred networks, click the wireless network, and then click Remove
  6. Click View Wireless Networks
  7. Under Network Tasks, click Refresh Network List
  8. Under Choose a wireless network, click the wireless network that you want to connect to, and then click Connect
In Windows, there is a power mode setting for the wireless driver that may help this issue. Follow the instructions below.
  1. Go to Control Panel, System, click the Hardware tab and select Device Manager.
  2. Click the + next to Network Adapters and double click on the wireless network adapter.
  3. Click on the Advanced tab, select Power Save Mode from the list on the left.
  4. Change the Value on the right to Off.
    The default setting is Maximum, which may cause issues similar to those described.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
  1. Click on Start, Settings, Control Panel
  2. Double click Network Connections
  3. Right-click your wireless network connection, and click Properties
  5. Under Preferred networks, click the wireless network, and click Properties
  6. Click the Authentication tab, click to clear the "Enable IEEE 802.1X authentication for this network" check box, and then click OK twice.
Sep 23, 2011 | Acer Aspire 5100 Notebook
I've installed the NETGEAR WN111v2 - It says that it have connected to the internet. but i yet no internet is found.
Open your run option on the start menu, type in msconfig, run it. go to the startup tab. uncheck the box next to Netgear WN111v2 Smart Wizard.
Next go to the start menu, My Computer. Double click Local Disk (C:), double click Program Files, double click Atheros, double click ACU (atheros client utility). Select Options from the main menu bar. Select "Select Client Software". Choose Windows. Hit OK. Close atheros and you should be in business.
Oct 09, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
Im having trouble i cant get on the internet unless im pluged in
IT seems that the wireless connection might not be connected.
if you facing trouble connecting to the wireless network using the wireless adapter utility then you can switch over to windows utility .
Sounds difficult !
It is very simple Click Here for more info about wireless connection problem
Oct 17, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Authentication failed!
You need to contact your isp for DNS, see:
Click here!
Feb 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wireless internet connection problem
Sound like you might benefit from ugrading your wireless drivers.
http://www.atheros.cz/download.php?atheros=AR5007&system=3
Jun 04, 2008 | Computers & Internet
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Networking Problem
By local network do you mean using a wired connection or a wireless connection? I gather you mean with a wire.
The following link is to a PDF page listing the lan drivers from acer for an Aspire 3680 --
Drivers Link
The second and third entries on the list both appear to be wireless adapter drivers for built-in hardware (atheros or broadcom). Are you sure the driver you have loaded is the correct driver?
To determine which if the two may be suitable for your machine try the following
Click Start and right mouse click My Computer and select properties
Select the general tab and click on device manager
find your wireless adapter probably preceded by a yellow question mark (?)
double click on the wireless adapter entry
get the name at the top of the general tab and
the click the details tab and record the
device instance id value
Report what you found back here in a comment.
Hopefully the name will contain atheros or broadcom of not I hope I can lookup the device instance id string to determine the manufacturer of the wireless adapter.
Dec 11, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite A65-S126 Notebook Logo
303 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
