Question about Panasonic Workio DP-3030 Printer
My panasonic DP-2330 gives a Fault when trying to print from a PC by usb connection. It says Print PC Data Cannot Complete Confirm Print Condition
  • trevor778 Sep 03, 2010
    I have tried what you have suuggested but still have that fault. The printer was working before we disconnected it and moved it from one location to another.
  • Panasonic Master
  • 4,737 Answers
I don't have idea what you've tried and what you've not. But this likely happens after the machine is moved.
First install it on another computer and try. If the problem persists, then use another data cable. Or if there's no problem on another computer, reinstall the driver on the first computer, reconnect it and if possible switch the usb port (try it on another usb port). That should work fine.
[Don't forget to restart the computer after the driver is uninstalled and reinstalled, otherwise you hard work will not worth]
I hope you can access all the other functions like copy, scan, etc.. or scanning not possible? I wish to know more about the problem.
If the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 03, 2010
  • Panasonic Master
  • 17,130 Answers
Please remove printer and uninstall software, then reinstall software and reconnect the printer.
Now check if the fault has cleared. If not have the printer checked on another PC to confirm the benefit of doubt on the printer.
If the printer faults then it is tthe failure of the motherboard. But if the printer is working well then you PC has some errors in the operating software. Use a restore to an old setting, open control panel--open backup/restore/ set to good restore point.
Also clean the system,scan or reinstall OS.
Please check to see if this helped.
Posted on Sep 02, 2010
Print pc data bypass add LTR paper
This indicates that you are trying to print a document that is letter size not standard A4 etc.
Sep 28, 2011 | Panasonic Workio DP-2330 Printer
Problem with panasonic dp-2330. i can not print from my laptop. i have the usb cable from my laptop to the printer/copier. i downloaded print driver to my laptop. the laptop recognizes the printer by...
You must enable the USB in service mode F5-88
While holding function key, hold original size ledger key, while holding those two, press the 3 key. This gets you into service mode. Press 5 then the start key. Scroll to #88 and set the value to 2
Apr 27, 2011 | Panasonic WORKiO DP-2330 Copier
How to scan
My dp 2330 copier prints dark shades(0.5 thick dark lines) even though the text you want to print is seen in the back ground. pls what should i do or whats the problem? Thank you .
Sep 11, 2009 | Panasonic Workio DP-2330 Printer
How to print envelope on Panasonic DP-2330 printer
You can download a user's manual from here.
It's a pretty large file, so I'm guessing there's something there about paper feeding or envelopes that will help you.
Good luck.
Aug 31, 2009 | Panasonic Workio DP-2330 Printer
Print pc data cannot complete confirm print condition
Hi, I've found solution when you are trying to print to Panasonic, and showed at the screen pc data cannot complete, you need to remove the security code at the Panasonic. as soon as you remove the code, you can print from windows. good luck. Oki Latief
Jun 17, 2009 | Panasonic Workio DP-3030 Printer
Panasonic DP-8045 printing with a Mac
the device needs to have postscript firmware installed as it comes standard with pcl firmware.
Apr 29, 2009 | Panasonic Workio DP-3010 Printer
Printing to copier
ah, probably it means that the department ID is activated on your copier.
go to the printing preferences on of the panasonic dp-4530 on your pc, the click the job type tab.
on the space provided you may type in the code that you use during copying or ask the person incharge on your company re department code.
Aug 18, 2008 | Panasonic Workio DP-4530 Copier
Booklet printing
You're right, most do offer that option from the print driver. I would check Panasonic's web site to see if they offer a postscript driver, that may have booklet printing.
Jun 12, 2008 | Panasonic Workio DP-2330 Printer
Networking a Panasonic DP-2330 Multifunction printer/copier.
Hello the MAC address is #28 located on the General Setting list under Function menu. Print it off. The key opp code is ussally 0000. Good luck I am in the same boat.
Feb 17, 2008 | Panasonic Workio DP-2330 Printer
Panasonic Workio DP-3030 Printer Logo
163 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
