Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
All of a sudden it's not turning on. My Hard drive is plugged in and I can hear it start to run, but the light doesn't go on and it doesn't show up on my computer no matter how many times I press the on button.
  • Western Digital Master
  • 3,287 Answers
It sounds like it powers up ok, but there is a problem with either / or the USB cable or USB port on the computer.
Try using a different cable if possible - if still no luck, try to connect to a different USB port on the computer. Older computers were built back when a USB port needed only power a mouse or keyboard. Nowadays, USB ports are powering devices with much higher power requirements. If yors is such a machine, you may have damaged the port. You can get around this problem by using a powered hub between the computer and the drive. The power from the hub will provide the power for the drive, so there will be no power taken from the computer to spin the drive.
Please rate my reply and good luck!
Posted on Sep 02, 2010
  • Steve Sep 02, 2010
    If your drive has a separate power plug, then disregard the powered hub explanation above; as it deals with the drives that get power from the USB port directly..
I have a SimpleTech 500 GB external hard drive (Model 96300-41001-013). It has been working fine for the past 2 years and all of a sudden when I turn it on, the blue light around the logo on top blinks...
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. You should have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Aug 20, 2013 | SimpleTech 250GB USB2.0 7200 RPM External...
Pc turning off
Be more specific. Turning off when? What happens when you try to turn it on? When you have the power cord plugged in do you see any lights? When you press the power button do you hear the fan running, hear the hard drive running, see anything on the lcd screen, hear the cd drive Click once, see the light on the cd drive drawer turn on for a second or two when it clicks, hear any beeps or blinking lights?
Mar 21, 2012 | IBM Lenovo ThinkPad X40 Notebook
Hi my ibm thinkpad r51 laptop starts up as normal,showing the windows xp logo.but after that the screen goes black but i can hear things on the desktop.pls i need ur help.thanx
Your laptop could have a back light problem.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 07, 2011 | Lenovo ThinkPad R51
SimpleTech 1TB External Hard Drive Silver My hard drive suddenly quit working. I plugged the hard drive in and powered on and the white power indicator light came on then just started flashing. The...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jul 25, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
160gb usb 2.0 portable hard drive that is froz
Try plugging it into a different USB port may not be enough power from that port
Dec 06, 2009 | Iomega Computers & Internet
SmartDisk turns on, has a blue light but shows no icons. I was in the process of copying from my camera. I turned on the SmartDisk, it showed a file icon and the HDD icon. I pressed copy and it...
I had the same problem but it felt like the drive was working. I took a chance, inserterd a 4GB CF card, and pressed the copy button. I hoped it would shut off after the copy was made due to the 30 second inactiviy timeout. After about 10 minutes, the blue backlight to turned off and it powered down. I plugged the Photobank into a laptop via USB cable and checked the original CF card files against the Photobank files. Success! All files were copied!
Jun 17, 2009 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
When i try to turn on my macbook nothing shows up on the screen and the white light on the bottom right turns on and stays on
Plug the power adapter in. Then hold down the startup button for 15 seconds. The light should go off and then after a few seconds. restart normally. The macbooks have a safety device that will lock up the drive if it detects sudden movements to protect the drive...
Let me know if you're back up and running. KEN
Apr 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
