Question about Epson WorkForce 600 All-In-One InkJet Printer
Do you have to hook the phone wire up to the modem to send faxes on a workforce610?
  • 8,197 Answers
Yes you do have to have the phone line conected to the workforce to send or recive a fax.
You can get the manual on the link below if you need it.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=130786&prodoid=63084540&category=Products
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 02, 2010
Installed Cox Digital Telephone. They disconnected my fax line. I have a Dell 968 printer and what I read on line is that it is not compatible with Windows 7 and that I would have to update the prin
Most newer fax machine seem to short line 1 and 2 together and this will cause a VOIP modem "called an eMTA" to go off hook. Your fax machine should have come with a phone jumper that has only a single line "2 wires inside it", you should be able to use that jumper to attach your fax machine to your house phone wiring. If you use a standard phone line jumper it has both lines "4 wires" and can cause your eMTA modem to go off hook which could be why it was disconnected.
Jan 30, 2013 | Computers & Internet
How do I hook up an HP v40 to my PC and a cable modem so that my FAX works?
You probably need to hook up to a landline telephone line, too. Or, you can use an "e-fax" service that lets you send faxes via internet. Basically, they would send your fax as middleman to the recipient. Windows Vista except Business version) does not have inherent fax support like Windows XP and Windows 7 Professional. And programs such as WinFax did not upgrade to Vista and 7. But, your fax modem should have come with some faxing software.
You put in modem card and then run telephone line to back. You can usually run a line to a telephone from the 2nd connection on the back with the telephone symbol below it.
Hope this helps you a litle.
Nov 20, 2010 | Computers & Internet
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
I have a lexmark 2600 and I can't get it to send my fax.
Try attaching another regular phone to the phone line and see if your line from the wall is working first. Then you need to check the cable from the wall to the machine. If all is good, your modem may be bad. Hope this helped!
Mar 12, 2009 | Office Equipment & Supplies
I have a Lexmark 5150 all in one.I recently hooked up to broadband.I cannot use the fax now. It says no communciation. How do I get my fax machine to work again? The printer and scanner work fine.Do I have...
Hi Brenda,
Your All In One wants a phone line hooked directly to it. It won't fax without a "POTS" line directly hooked to it. POTS stands for "Plain Old Telephone Service" which is the line with good old dial tone on it.
Dec 17, 2008 | Lexmark Computers & Internet
Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
Nov 09, 2008 | HP LaserJet 3050 All-In-One Printer
No filter
There you go. Stop by Radio Shack and pick up a DSL filter and hook it up to the wall outlet of your fax machine. If the DSL modem is next to your fax machine, plug the fax machine into the outlet marked as phone.
I just got done doing this to both of my offices. Typically the phone company will use your fax line to piggyback the DSL. All you have to do is make sure your DSL modem output goes to the fax line either through the wiring block in your office or directly to the back of the modem itself.
That way you won't need the filter.
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Cannot send faxes!
Take an ordinary phone and connect it to the auxillary port on the back of the fax. Call the number you are trying to fax and listen to see if it connects and the other fax picks up. Be sure you are using any prefix numbers required such as a 9, or a 1 and area code if required. HP recommends that you use a 2 wire phone cable, not a 4 wire (see how many metal connectors are in the jack to tell). Of course, if you are on a DSL line you want a filter installed for the fax. If this doesn't work, try a different phone cable. You could also have a bad modem in the fax. That would be last on my list. Good luck.
Jun 10, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Fax is saying no dial tone and not sending.
if you are using xp home you have to go into the utility and install the fax program its there but not installed and turned on this is most likely your problem, because once installed it will automatically hook itself to the modem.
Dec 13, 2007 | Lexmark X1270 All-In-One InkJet Printer
Fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Nov 08, 2007 | Computers & Internet
Epson WorkForce 600 All-In-One InkJet Printer Logo
108 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
