Question about Maytag Dryer Lint Filter Screen 33002970
Dyer is not heating maytag dryer D8000
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rtw
Posted on Sep 29, 2010
Dyer not working, no heat
fault is from the heating element of your dryer.
Have the heating element replaced and it will be restored.
Regards.
Sep 29, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
Gas valve on dyer will not open
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Dryers
The dyer blows cold air - no heat
PROBLEM WITH THE HEATING ELEMENTS, THEY ARE PROBALLY BURNED OUT, CHECK THEM YOU WILL HAVE TO PULL THEM OUT AND CHECK WITH A METERN TO SEE IF THEIR OPEN, BUT I WOULD SAY THATS IS THE PROBLEM
Apr 26, 2010 | Maytag Neptune MCE8000AY Electric Dryer
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't heat
sounds like your heating element
Jun 09, 2009 | Maytag MDG4000 Dryer
Maytag neptune dyer
Hi there. Actually, you could find a white dryer and spray paint it. I have done this and the appliance paints are amazing.
May 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Dryer Lint Filter Screen 33002970 Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
