Question about Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer model #GLER341AS2
How to remove the top? which screw do i remove first?
    Genius:
  • 1,028 Answers
Along back edge are 4 screws remove and slide top forward
Posted on Jun 12, 2008
Frigidaire model# GLER341AS2 humming noise
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dryer, GLER341AS2, is making a humming noise. It could be a possible issue within your belt, motor, or the blower assembly. The manufacture provides to a dryer preventative maintenance kit part number 5304457724 and it costs $45.12 plus tax and shipping. I would also recommend contacting a professional to help avoid any unnecessary purchases. I hope this helps. -Matt
Aug 15, 2014 | Frigidaire Dryers
Frigidaire dryer gler341as2
Good Afternoon Friend, this is Z. I am happy to assist you!
I see you have a Frigidaire dryer, GLER341AS2; however what exactly is your concern? Are you seeking an Owner's Guide or is your dryer experiencing an issue? With this information I can better address the issue at hand. Thank you!
Jul 25, 2014 | Frigidaire Dryers
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
My frigidaire dryer model number gler341as2 is giving me a burning smell why is that?
Hi kmcgilvery...
That burning smell is probably a lint build up in the blower system of the dryer.
You will need to remove the back of the dryer and look for the vent tubing going to the hose connected to the outside. Once you find the tubing then disassemble and clean the tubing and blower wheel of dust...then clean your flexible vent tubing you have attached to the back of the dryer.
Please take time to rate me
Sep 05, 2011 | Frigidaire GLER341A Electric Dryer
Frigidaire Gallery model Gler341AS2 drum is sagging towards 6 o'clock and causes a gap that snags clothes. What parts need checking to find the cause of this?
seals on front and back, but drum rollers/glides here is a website, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Apr 17, 2011 | Frigidaire GLER341A Electric Dryer
Squeaking noise frigidaire electric dryer model # gler341as2
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 31, 2010 | Frigidaire Dryers
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
277 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
