I'm trying to change the name that appears at the top of my fax sheets when i fax
    Genius:
  • 1,218 Answers
The name that appears on the top of the fax's you send is called the TTI (Transmit Terminal Indentifier ) and should be in the basic set up instructions for your Fax machine....as it is different for each manufacturer I am unable to help further as you have not specified what make or model you have.
Posted on Sep 02, 2010
2 Suggested Answers
old marine
  • 1924 Answers
SOURCE: how do i change the name/heading when faxing?
See chapter 3 (specifically page 3-6) of the User Guide which can be viewed/downloaded here.
Posted on Sep 28, 2009
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
How do you update name id?
Thank you for your question.
I have located the manual online for you to download for your convenience. It is a small download of 6Kb.
http://office.manualsonline.com/mdownloads/898a6efe-df1c-455e-b773-8c58a0fb3818.pdf
The procedure you need to follow is outlined on pages 1-16 to 1-20 and are user friendly. The size of the font can be increased at the top of the page of the PDF file, it is rather small.
Kind regards.
Apr 27, 2010 | Canon LaserCLASS Fax 710 Printer
How do I remove the name that shows on top of a fax?
You may remove it by using the software.
The labellings you referred to is the header and footer.
You may remove them
Mar 10, 2010 | Office Equipment & Supplies
How do i change the name/heading when faxing?
Sep 28, 2009 | Canon FAXPHONE L80 Laser
How do I change our sender name at the top of each fax
To enter or change the name that appears on the top of your cover page, the procedure is as follows:
  1. Press FUNTION 7
  2. Press 1
  3. Press SET repeatedly until your current name shows
  4. Use < > arrows to move cursor to the desire position, from here you can change the name to your liking
  5. Press SET
  6. Press STOP
Best of luck.
Greg
Jul 17, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Change name that appears at the top of outgoing faxes
press Menu
press 5 then 2
select the "fax header" option
when your name appears, enter your name using the keyboard.
the keyboard is similar to cell phone keyboard.
press enter
enter the fx number when your are prompted
press enter when finish.
if you still haev problem, please click on the following link for HP Officejet6110 users' manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
43 people viewed this question
k24674
