I have a samsung dnie dlp tv that makes a buzzing sound when you turn it on.
  • 11,800 Answers
The sound is made by the power source that is overstressed by a failing part - it's about to die. This usually happens because the capacitors on the power source have aged and they starting to behave as a short.
Open the tv and replace them all.
Posted on Sep 02, 2010
  • vette933 Sep 24, 2011
    is this expensive.
  • Azrael SRL Sep 24, 2011
    Less than $25 in parts. But you need a basic experience in soldering electronic components to do the replacement - if you have never done this before, calling a repairman will be mandatory and that will cost you another $125.
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
My tv makes a buzzing or grinding sound when i first turn it on and stops after the lamp warms up. is this just my lamp starting to die?
You may have a bad color wheel if your TV is DLP based. If its a Samsung then you most likely have a failing color wheel. Lamps will not cause grinding or buzzing sounds.
Jun 02, 2015 | Televison & Video
When you turn on the TV it makes this buzzing sound like something is spinning inside the TV. After a while the TV cut off on its own. It has a new bulb in it.
check the fan that cools the bulb. if its rubbing something that would make the buzzing sound, and if its not cooling the bulb it will shut off when it over heats.
Sep 14, 2010 | Samsung DLP HL-P5663W 56" TV
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung dnie tv wont turn on. The tv will make sounds and not light up.
either the lamp is burned out, the ballast for the lamp is not firing or the power supply board may have failed.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
I have a samsung dlp that makes a horrible buzzing sound and it turns off, all the lights blink and the color flashes in and out.
The problem is likely the color wheel paste the link attached for more info
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
Buzzing
it could be just heating up, how long does the sound go for?
Mar 17, 2009 | Samsung HL-R6167W 61" HDTV
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV is making a buzzing sound. Sounds like something spinning. Can hear it speed up to full spend when turned on and slow down and stop when powering off the TV. Loud at times.
More than likely this is the cooling fan. I have a Samsung DLP myself, and at times, I can hear the fan running also. There could be something wrong with the fan, but I kind of doubt it. Just make sure that the TV is in a spot with lots of ventilation....otherwise, you might have to live with this noise.
Hope this helps!!
Chad
Oct 08, 2008 | Televison & Video
Televison & Video Logo
372 people viewed this question
Top Televison & Video Experts
