Question about Kitchen Ranges
I have a Runco VX2c Projector. When it runs in ceiling mode after a while the projector fails and then says error 0202, the projector picture shuts off and fans stay on What is that error relating too
Most likely it is the fan
Posted on Sep 16, 2010
Projector keeps switching itself OFF
The projector is probably overheating you need to check fans and lamp inside
May 28, 2008 | Audio Players & Recorders
Runco picture upside down
Yes possibly because you have done a complete system reset and not a lamp hour reset so you will need to go into image or screen settings and select front view ceiling mount configuration
Apr 14, 2013 | Office Equipment & Supplies
Projector shut off
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video. Pretty easy fix.
Jan 02, 2012 | Runco CL-410 Multimedia Projector
How do I replace the bulb hours in my Runco Media VX-4000d Projector? I already replaced the bulb. Thank you for your help!
Please contact Runco support at 1-800-23-RUNCO. We can assist you.
Sal Di Giacomo
Runco International
WW Service Manager
sal.digiacomo@runco.com
Aug 05, 2011 | Runco VX-5000ci Multimedia Projector
My RUNCO projector is projecting upside down and we cant seam to fix it. Any advice?
1. Press the menu button on the remote to bring up the on-screen menu. 2. Select the Setup Menu 3. Select Picture Orientation 4. Change the configuration so that the image and text appear correctly.
Feb 28, 2011 | Runco Reflection VX-1c Multimedia...
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Jan 09, 2011 | Runco CL-410 Multimedia Projector
The picture on our runco projector is upside down
in the menu there is a picture flip option. some projectors can be mounted on the ceiling which you will have to do this, you just need to put it back. keep looking in the menus and you will eventually find it.
Jul 19, 2009 | Televison & Video
Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Mar 07, 2009 | Eiki LC-X50M Projector
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
