Question about Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
Dishwasher stays in wash mode for hours. - Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
**What I`m about to share applies to Almost all Electronic control B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.**
Based on your description I know what the problem is, though you may not like it. I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line. Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher never completes a cycle or takes an extremely long time, is the control has detected a heating error. Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The issue with your dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
This is why it runs really long/forever unless you "stop" it or by pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The image here will differ slightly from yours, but the remedy and procedure is the same.
This will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water.
You can also enter a test to check for proper amperage via the use of an ameter as such...
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries.
Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
Macmarkus :)
Posted on Sep 02, 2010
My dishwasher stays on the washing mode, it never moves onto the dry cycle.
Seriously, you may want to call a service repair guy to look at this unit if it is something you want to keep and is out of warranty. You are wasting lots of energy, with washing and draining again and again.
Feb 02, 2016 | Dishwashers
Fisher washer stays on clen for over 3 hours
"Fisher washer stays on clen for over 3 hours" ???
I think you mean the "Dishwasher stays in the clean cycle for over 3 hours", right? First question is "What cycle?" If it's the Pots and Pans cycle, or "Pro-wash cycle" , or "Normal cycle with extra wash heat or sani-rinse options selected, then yes, this is normal! A Normal cycle (without added heat) will take about 2 hours. And a short or quick or 1-hour cycle will take less.
Sep 25, 2014 | KitchenAid Dishwashers
Stays in wash cycle
The timer circuit on the panel needs to be replaced. It is not going through all of the cycles!
Jan 22, 2013 | Washing Machines
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
Dishwasher stays in cleaning mode and does not cycle to rinse.
Hello their sounds as though water heater has failed if it doesnt heat it defaults to a 3 hour cold wash and never finishes cycle eg doesnt go through rinse stages.will need a new heater service tech to change as fairly complicated.
Nov 02, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
Stays in wash cycle Whirlpool Dishwasher Du1050SS
the stat is mounted to the bottom of the tub it will read closed if good if it reads open replace it
May 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Wash cycle
momrules, it could vary depending on the water entering the dishwasher. On a heavy cycle normal time is about 85 minutes not including thermal holds ( pauses that heat the water). On a normal wash, 68 to 75 minutes not including thermal holds. If the water entering the dishwasher is not at least 120 to 140 degrees the dishwasher will pause in cycles to heat the water before advancing. So 120 minutes is not unrealistic. The heaters in the dishwasher are low wattage and will only heat the water approx. 2 degrees every 5 minutes. Catriver.
Nov 30, 2007 | Kenmore 24 in. 17512 Built-in Dishwasher
Bosch 24 in. SHX46A02 / SHX46A06 Built-in Dishwasher Logo
456 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
