Question about Janome Harmony 2041
My machine is sewing fine but it is loud. I first had a squeaky noise now it is more like a banging. I have taken it apart to clean it out of lint a couple of times but there is no lint in it. please assist
  • 340 Answers
Try oiling your machine.
Posted on Sep 02, 2010
Why would machine make loud noise like machine gun. Stitching is fine but am afraid to use because it sounds like it is hitting something in casing.
Probably best to have the machine serviced. Sometimes a bent needle will make a racket if it is hitting under the needleplate. At any rate, it is probably better to get it fixed than injuring yourself or breaking the machine.
Mar 20, 2016 | Brother PE700 Computerized Sewing Machine
How do you adjust the bobbin tension on an emerald 118
There is a screw on the bobbin case that can be used to adjust the tension. However, first I would check that there is not a thread or lint caught in the tension spring of the bobbin case. Use a stiff brush to clean bobbin case. Use a needle (or other sharp point tool), and check spring area for thread.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
I have a Kenmore 385.16221301 sewing machine and it makes a loud noise at high speeds
it's possible that something is loose or worn slightly to make the noise
Feb 27, 2012 | Sewing Machines
Lould noise when sewing. already, cleaned inside, oiled, changed thread, needle and begins to sew correctly but while sewing becomes loud again. bobbin casing does not appear to be damaged. machine is...
Have you taken your throat plate off and cleaned that out? You have to take a stubby short screwdriver and remove the throat plate. Sometimes, lint and cloth build up in there and it looks like felt almost. I was surprised when mine had it, I always followed the standard way of cleaning and lubricating until my friend told me about this. I was shocked, to say the least, that she was right. And my machine quieted right down. Hope this solves your problem
Dec 30, 2010 | Brother CE4000 Computerized Sewing Machine
My machine is making a loud banging noise
These are the things that cause my machine to make a "banging" sound:
The machines with the horizontal/drop-in bobbin sometimes collect lint in the bobbin case.
Sewing fabric backed with a synthetic/foam/vinyl or adhesive.
Wrong size needle for the type of fabric being sewn.
Mar 13, 2010 | Sewing Machines
The timing on my sewing machine is wrong so that it making really loud banging noises does any one know how to stop this
in general, when your machine begins to make the loud banging noises, it tends to indicate a timing issue. The best way to fix this is to seek the help of a service person who deals with sewing machines. a regular service/check of your machine is recommended to help prevent these issues from arising, or regretably something more sinister.
sorry I couldnt give you a quick and cheaper answer
Oct 04, 2009 | Sewing Machines
Machine makes banging noise
wow, taking apart and putting it back together is a big feat. I think you should check the needle and its height, could be to low and is hitting just enough to make noise and not break.
Jul 24, 2017 | Brother XL-2600I
Loud noise while sewing
Could you let us know which machine this is.....
In the meantime....the damaged bobbin is not good, replace it/them........if you have a top loading drop-in bobbin, check for needle damage on the plastic bobbin case (remove needleplate to access).
If there is evidence of needle strikes, if mild, you could try to use very fine wet & dry emery paper to smooth, if severe, buy a new bobbin case.
There may be a load of lint under and around the bobbin case too, remove and clean up this area. If very dirty, use methylated spitit on cloth or cottonbud (QTip) to remove grime (don't soak)
Bargainbox
Jan 27, 2008 | Sewing Machines
Needle won't pick up bobbin thread
Is it possible the bobbin is in backwards? I have also found mine to be fussy with cheap bobbins.
Jan 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Janome Harmony 2041 Logo
155 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
