Question about Nikon Speedlight SB-600 TTL Flash
SB-600 Flash not working
I am having problems getting my flash to work on my Nikon D-100.  I had it before set up to automatic and it worked.  For whatever reason now the flash does not work.  It turns on but it is not firing the flash when I shoot.  If anyone could help I would appreciate it.  It might the settings in my camera of something I might not be aware of?
  • 111 Answers
Make sure both camera and flash are set to TTL automatic mode. One time this happened to me and I had forgotten to lock the flash to the hotshoe connector.
Posted on May 15, 2008
My nikon d90 doesn't works when i put the flash sb-600
Could you provide some details? How does it not work? Does the D90 not turn on? Does it take a picture but the flash doesn't go off? What exposure mode(s) are you using?
Apr 02, 2013 | Nikon Speedlight SB-600 TTL Flash
I have a sb-600 flash. It works fine but it has
Try doing a reset - press the "Mode" and "On/off" buttons together for a few seconds and you go back to factory settings. Sounds like you got into some funky mode, assuming everything else is working ok.
Mar 09, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a new D3000 and a nikon SB-600 flash. I
From the Nikon site, do you have one of these flash units.
Support for the Nikon Creative Lighting System when using SB-900, SB-600, or SB-400 Speedlights, or the SU-800 Wireless Speedlight Commander
If so You set the flash mode to "comander" the pop up flash must be UP
This Video by Nikon shows how but you will have to read the manual to get a full description go to the flash section http://www.nikondigitutor.com/eng/d300s/index.html
Then look at them all :)
Jan 21, 2010 | Nikon D3000 Digital Camera
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Flash is not working for a nikon sb-600 speedlight
    zoom the flash all the way in so you can see if the flash bulb is broke
    Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
    Camera flash problem (Nikon)
    ok,
    try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
    randy320sgi
    Jan 07, 2009 | Nikon Cameras
    SB-600 Power Zoom stuck at 14mm
    I struggled with this one but then, on the basis that if all else fails read the manual I found the answer. It's soooo simple. The wide-flash adapter is set. That's the little pull-out screen at the top of the flash which folds down over the flash-head. If it's pulled forward it activates the wide angle setting automatically. Push it back in and you'll be fine. tony k
    Dec 16, 2008 | Nikon Speedlight SB-600 TTL Flash
    Random pictures
    Check in the user guid for your camera about their recomended shutter speed setting for the flash.
    Try using the camera and the flash in "A" (automatic) to start with.
    Jerry G.
    Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    184 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
