Question about GE Refrigerators
What is the sealed pan(bottom drawer) in a prfile for seems to rot fruit
Removing clear plastic section from from solid part to get trapped dirt
Posted on Sep 19, 2010
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water in the vegetable and fruit drawer
There is a fix kit out by Samsung for this issue. you need to contact Samsung and get the kit. Its a defrost heater probe for your drain, and some foam to seal the evap on the fridge side.
Aug 05, 2013 | Samsung RF265AA Bottom Freezer French Door...
Fruit is freezing in the bottom drawer of the KitchenAid KSCS25FKSS Side by Side Refrigerator
There is a chance that your refrigerator needs defrosting. Remove everything and unplug your refrigerator, open the doors and let stand for 12 hours. Sometimes the air vents restrict with ice causing this trouble.
http://www.on-timeapplianceplano.com/refrigeratorrepair.html
Jul 23, 2012 | KitchenAid KSCS25FKSS Side by Side...
Have Breadman TR2200c. The red drive shaft "seal" in the bottom of the bread pan seems intact. The drive shaft stopped turning. I forced it out of the shaft tunnel, and the clip was rotted. 3...
I think you're going to have to take out the seal and put a new retaining ring on the shaft to keep it from falling out the bottom. If you're lucky you'll be able to pull out the old seal without destroying it.
A 5/16" external retaining ring should do the trick. Hardware store or Lowes should have 'em. Depending on how difficult you find it to force the ring down into the well in the pan to put in the shaft's groove, you may need a retaining ring pliers. The cheap ones from Harbor Freight (around $3) work fine.
Aug 08, 2011 | Breadman TR2200C Ultimate Bread Maker
Display F1 want do anything else
An F-1 is a fault code that comes on when you have accumulated at least 1/8 of water in the base pan under the drawer. You have two options, first one you can unplug unit from the power source and allow the air in the room to dry it out or while unplugged you can remove the drawer by releasing the tabs on the bottom of the lowest drawer and slide out the drawer to remove the water. There are a couple of different models and you didn't leave a model number to allow me to send diagrams too.
The true fix is to determine why the base pan is collecting water, here is a couple of common issue that could create this problem, drawer too full and seal to drawer did not seal, too much soap, bad seal to lid (that covers drawer during wash) or the hoses in the back of the drawer have came loose and prevent the lid to lower and cover the drawer.
I hope this helps...
If you need more help let me know and I can give you pictures, parts lists, and step by step instruction with the model number located on the rim of the upper drawer open..
Jul 15, 2011 | Fisher and Paykel Dishwashers
Bottom unit does not always seal and causes water to collect in bottom pan which throw unit into f1 status. Sometimes it stays sealed and is difficult to pull drawer out. Is there a way to reset the unit...
These dishwashers are very sensitive to grime collecting around the drawer edges. Try cleaning with a damp cloth by rubbing along the top edges and the sides where the drawer door sits flush with the body.
Also trun off power at the mains and then turn back on after a short wait.
Oct 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
1,250 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
