Question about Home
My Price Pfister Shower Head is squirting water in a comcertrated stream and not a spray. I have cleaned the shower head and it did not make a difference. Help>
    Problem Solver:
  • 8 Answers
Check flow restriction device
Posted on Sep 03, 2010
Our shower head is very similar to the Price Pfister Savannah model. Recently we were forced to replace our water heater. As a result several faucets were blocked up with debris. We suspect that is the...
The simple method is to take the faucet head off the extension pipe that comes out of the wall. It will take two pair of pliers and a firm grip to take it off. Using a wet/dry shop vac at the supply end and a garden hose at the shower end, force water backwards through the faucet head.
Jan 02, 2011 | Price Pfister 01-81BC Savannah 3 Handle...
The device the sprayes water from the shower head has broken. The shower head does not unscrew for the shower arm. The shower arm is attached behind the tiled wall. How do I remove the shower arm and...
The shower arm should be screwed into an elbow inside the wall. Unscrew the shower arm by putting your pipe wrench on the arm and unscrewing in a counter clockwise direction ( lefty loosey, righty tighty ) . Measure the length of the arm going inside the wall and make sure your replacement has enough length to reach. Teflon tape the inside end ( the end going in the wall ) and wrap a rag around the new arm, then screw into the elbow going clock wise , stopping when it starts getting tight and with the bend facing downward. Install shower head.
Nov 20, 2010 | Price Pfister Home
The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
Jul 11, 2010 | Price Pfister R897EBK Brushed Nickel...
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
My shower head leaks
for some reason the cartridge set up does a sporadic drip which is infuriating but replacing the insert will not fix it
after the cartridge there is just an empty hose to the shower head and no pressure
Nov 13, 2017 | Price Pfister R897EBK Brushed Nickel...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
Feb 13, 2009 | Price Pfister Ashfield Single Control...
No shower water
the spout is also the diverter which sends the water up to the shower head. Assumming that the shower head isn't clogged with lime you should be able to solve the problem by removing the spout and taking it to a hardware store or home depot for a replacement. Most spouts just unscrew but some have a set screw which holds em in place. Look for the set screw on the underside of the spout. good luck
Jan 18, 2009 | Price Pfister Ashfield Single Control...
Home Logo
75 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
