Question about Haier HPAC99ER Air Conditioner
Brand new, Remote not working, starting and stopping with button on the front. Batteries new, commercial cool Model #APO77R-RBG Please Help,Thank You
Koch Air Conditioner Remote not working :(
You may have to replace the remote control.
Dec 15, 2017 | Heating & Cooling
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Remote control not working properly
Try cleaning the contacts that connect to the batteries. A pencil eraser will clean the contacts.
Jan 27, 2010 | Televison & Video
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
My remote for my akai pdp42z5ta stopped working
Stevenson
Yes, I can help you either fix the original or get you a brand new one. By the way, did you change the batteries. I know you did, but this procedure is the first step. If you change the batteries and the remote doesn't work, the problem can be inside the remote, specially if it happen to be dropped. Or the sensor in front the tv may be bad if does not respond to the remote. The best way to check the remote control is with infrared checker, an special equipment I have at the shop. I can ckeck it with that for you and fix it as well. Please e-mail me at Stevebuy31@hotmail.com
Dec 03, 2008 | Akai PDP4225M 42 in. Plasma Television
Dino Buddy not responding to r/c
I Replaced the batteries in the dinosaur, because mine did that after only a few hours. when the batteries start to die, only the demo switch works...
I hope this helps!
Nov 29, 2008 | Lillian Vernon Remote Control Dinosaur...
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
RCA Universal Remote stopped working
I have the same problem on my RCA UNIVERSAL remote too..any one could me ?
thanks
Jan 08, 2008 | RCA 244889 Remote Control
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Haier HPAC99ER Air Conditioner Logo
43 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
