Question about Electrolux Washing Machines
Electrolux front loader, softner dispenser doesn't empty
  • Electrolux Master
  • 43,501 Answers
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Posted on Sep 03, 2010
My fabric dispenser is filling up with water when it has emptied the fabric softner. Is there a way to remove the drawer?
Depends on what model often the Kenmore or Frigidaire who makes most of the kenmore front loaders have a little tab in the upper left hand corner that you can depress to slowly pull out the draw. I looked at the owner's manual it says this is normal.
Sep 05, 2014 | Washing Machines
WHY DOESN'T FABRIC SOFTNER DISPENSOR NOT EMPTY ON MAYTAG NEPTUNE FRONT LOADER ?
there is three switched valves for cold and one for hot
the three cold are prewash main wash and softener
at the back of the valves back of the machine
there is a little cage inside the valve header
check its not full of dirt
you can remove them for cleaning with a pair of flat nose pliers
if this isnt the case replace the switched valve related to the softener
compartment water intake
Aug 11, 2014 | Maytag Washing Machines
How to clean my washing machine Electrolux Front Loader
Hello -
First rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Sep 21, 2012 | Electrolux EW1000i Front Load Washer
Fabric conditioner not going down
Fabric conditioner does not always go down, maybe you have a blockage on soap drawer, This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jun 03, 2012 | Whirlpool Washing Machines
Fabric softener won't empty out in my frigidare front loader
heatman101
Jan 24, 2011 | Washing Machines
The softner tray doesn't empty into the machine.
you could have a glogged up dispenser housing ,or a valve that is not working , each one has a valve that injects water through little holes into the dispenser.could be a bad valve, dispenser housing or enen a board. hope this helps
Sep 19, 2009 | Kenmore 43142 Front Load Washer
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fridgidaire front loader washer/ problems with softner dispensor
In the back of the dispenser is a button / lever to press down to remove the entire dispenser. Remove it and take off the cover over the fabric softener / bleach chambers. You may find some junk under the cups in that cover, or in the tubes sticking up through the bottom of the dispenser.
The way this thing works is like this: You fill up the dispenser with the liquid, but that liquid doesn't get up to the top of the tubes. When it's time to dispense, the washer adds water to the appropriate chamber, raising the level to above the tube. The liquid then goes down the tube, creating a suction which (ideally) draws the rest of the liquid up into the cup, over the edge of the tube, and down the dispenser. The washer will add water several times to accomplish this. The system isn't perfect, but it usually works with few moving parts.
If the fabric softener is especially thick, it will have a hard time getting siphoned down through the tube. If it looks as thick after the wash as it did before the wash, the machine isn't adding the water to the cup. I believe on the Frigidaire, there's a separate valve (all part of the same valve assembly) for each dispenser chamber. If it isn't adding the water, you'll have to replace the whole valve assembly.
Mar 12, 2008 | Washing Machines
Washing Machines Logo
1,625 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
