Frame collaps Telefunken ttv280
A single horosontle line in the middle
  • 131 Answers
If you have a line in the middle it is verticle ic and capacitors that go bad. some times cold solder joints.most of time part and repair is cheap around 85 to 160
At least now you no what your up against when you call a service center
Thanks jay
Posted on May 10, 2008
Telefunken crt model Ttv280 Frame collapse how will i know if is the vertical ic or the jungle ic
Absence of Vertical scan output signal. You have to check its vertical scan output section circuit to detect and rectify this fault.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Similar fault symptoms and repair work has been described by the author.
Jan 09, 2017 | Televison & Video
I want the troubleshooting guide of frame collapse crt tv Telefunken model TTV280
The Horizontal oscillator is not working. The transistor is about 20 dollars and the flyback transformer is more. Labor and parts isn't worth fixing. Get a new TV. It's cheaper.
Jan 07, 2017 | Televison & Video
Colour changed bad on telefunken ttv280
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 10, 2014 | Televison & Video
How to reset Telefunken TTV280 to factory defaults
It is not with the the fault as you suspects. It is the fault with its main system control memory IC. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there
Nov 22, 2012 | Televison & Video
My telefunken has a problem. The guy that tried fixing it says that the tv is in PROTECTION (the light just flashes and no picture or sound comes through. Please help
If the set is in protection mode, that is normally caused by short circuit line output stage, short circuit frame output stage, short circuit audio output etc. It shouldn't be too dificult to fault find, even without a service manual.
Look for an authorised Telefunken service centre.
Mar 14, 2011 | Televison & Video
Sansui SV2916 has a white horizontal line across the screen and there is a picture within that line. What causes the picture to be reduced to a white line?
That is called frame collapse because the picture "frame" has collapsed into a single line. The usual cause is dry joints if it went all of a sudden or capacitors if it took a while. The frame outpur IC may now have failed but not always.
Feb 13, 2011 | Televison & Video
I need a diagram of a dodge neon brake lines, do the rear lines split in the middle or do they run all rhe way back seperatly? Thanks
They are separate.
Go to this web site for excellent instructions on how to change them. There are many illustrations.
There are also factory pre-made lines from the dealer for $20 for the pair. They were part of a recall and the cost is very low. I just installed them. Get the part numbers at the web site above.
Sep 16, 2009 | 1997 Dodge Neon
I cant get it lock so baby can play in it!!!!!
you can try pulling the middle piece up and keep it up while pulling the sides into place, they should lock and you shouldn't be able to push on they and have them collapes. After the sides are in place, push the middle piece down and that should do it.
Feb 06, 2008 | Cosco Beatrix Potter Playard Crib
Hi there,it looks as if you have a frame collaps,this is the first time i have ever heard of this on an LCD tv,i take it that there is no picture at all only a thin line.
Dec 23, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
T.V. overheating in our conversion van
If you suspect overheating then try removing the back and clean out with a long, wooden handled artists brush. Make sure the children are not about and try it with the back off, but do not touch things inside. You may blow cold air if you see what is overheating. See how long it works OK for. If it works without going off (assuming it was very dusty inside), then replace the back. If it needed a fan to keep it working you may find out what needs replacing.
Oct 22, 2006 | Audiovox AVT1498 TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
