I have a Toshiba/VCR MV13N2C. When I insert the video cassette, it automatically pops back out instead of going into play mode like it used to only yesterday. Do I need to change some setting via the menu ? Thanks
A library sticker peeled off from a tape and got stuck on the upper face of the video input slot. Once that was removed everything worked fine.
Posted on May 14, 2008
Why does the tape get caught in my toshiba rd-xv45kb recorder when i try to eject the cassette and the tape snaps
Not sure about the Toshiba but generally when inserting a cassette it is lowered onto the tape drive. There is a device that will register the presence of a tape which used to commonly be a phototransistor or similar mounted on a short post that is covered by the cassette.
Once the machine knows a tape has been inserted, when play is pressed two vertical rods move towards the heads dragging the tape with them enough for it to make contact with the sound head and wrap part of the way around the video head to make playback possible.
When stop, forward or reverse winding or eject is pressed those two rods move back to the starting position and the surplus tape is wound back into the cassette.
If a cassette ejects leaving a loop of tape that can mostly be pulled out little damaged the reeling in mechanism isn't working. If the tape is jammed and comes free only after breaking the rods aren't returning to the start position.
Engineers use an empty cassette case suitably modified so once the vcr cover has been removed the operation can be observed. The problem might be a worn belt or rubber drive wheel or a problem with the hidden linkages - or it might be an electronic problem.
Apr 22, 2017 | Toshiba Televison & Video
Video Cassette is being automatically ejected when I insert it for viewing
You need to take the cover off and look inside to see if there is something inside that should not be. Perhaps you can look with a flashlight through the entrance hole. You could pick up the machine and shake it and see if anything is rattling around. These things have many plastic and nylon parts which can break over time and the machine will sense a problem and eject. If you cannot find a problem by the suggestions above then it will need to go for repair-unfortunately it would probably cost more than it is worth to have it repaired.
May 16, 2014 | Goldstar GBV241 DVD Player/VCR
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
When I put a cassette in the VCR it plays for about 5 seconds and then shuts off by it's self. I have tried numerous cassettes and they all do the same thing. I do not have a head cleaner what else can be...
When a tape is inserted into a machine a switch called a "mode switch" tells the electronics of the machine what mode the VCR is in. If this switch goes wrong ie: it sends out wrong position message, the electronics powers the machine down.
So your machine could have a faulty mode switch. However the mode switch might be OK, but forced into a wrong position by a broken part in the VCR.
Cleaning the head will not help. Sometimes a spray of Servisol Video 40 on the mode switch will clear any dirt that could be causing a false reading. But it won't do anything if it or any part of the video is damaged.
I'll post below pictures of a mode switches to help you find it. It might look a bit different though on your model.
Jan 16, 2011 | Toshiba M665RB VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
Playing vcr problem
Dec 17, 2007 | Canon ZR100 Mini DV Digital Camcorder
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
