Question about Toshiba Portege R100 Notebook
How do i install windows xp on r100 note book had to replace hard drive
oguns23
  • 55 Answers
SOURCE: laptop hard drive
if you turn it opside down their tree place at the back u check the middle one then you remove the old one carefully so that you wont spoil the connector and if you want to install wondow xp insert cd into the drive then go to setup set your cd drive as first boot device then you press f10 to save and restart after that it will ask you press any key to boot from cd drive you press after press pressing you can now follow the screen direction
Posted on Jun 03, 2008
SOURCE: drivers for c722tu note book with windows xp professional installed
ok... here is the driver for windows xp professional
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=3645596&lang=en
juz click on the link download the driver ....
Posted on Aug 21, 2008
rtrahan
  • 741 Answers
SOURCE: CANNOT FIND THE DRIVERS FOR WIRELESS AFTER REPLACING HARD DRIVE
First you need to get the name of your wireless card. You may be able to find it in start>accessories>system tools>system info and click on network adapter. Once you have the name of your adapter, go to www.microsoft.com and search for the Hardware Compatibility List. This will have all of the wireless cards that are compatible with XP. They also have the drivers at the same place. Second choice, go to the wireless manufacturers website, they always have the latest drivers available for download. If you have any questions let me know.
Don't forget to rate this with 4 stars before you log out.
Posted on Jan 17, 2009
kbdesign
  • 370 Answers
SOURCE: toshiba portege r100
Now, that is a tough one. Only way to unlock the hard drive is to have the original password. You will not even be able to access it retrieve any data you want to save.
Thinking you are in the market for a new hard drive and a complete reload of the system.
Posted on Mar 16, 2009
SOURCE: toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Posted on May 24, 2009
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Audio is not working on compacq presario c738tu note book earlier windows vista op changed over to windows xp op.
On HPs web site you will find the driver that you need to install to replace the old drive for vista
When you select the model of your lap top it will come up saying windows vista or XP and make sure that you select XP so that you insure proper installation of the driver
Jun 08, 2010 | HP Pavilion dv6000z Notebook
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Goto bios - disable sata operations and select hard drive type as normal, disable ahci, disable acpi
May 29, 2010 | Gateway T-6330U Notebook
Corrupt or missing file but have no disc drive as it is a note book please install a copy of above program windows root system32 ntoskrnl.exe
IF YOU ARE USING A NOTEBOOK, IN MOST CASES YOU SHOULD HAVE A RESTORATION PARTATION ON YOUR HARD DISK.
If this file on your CD/DVD is corrupt, the chances are good it will find many more needed to complete the installation.
Find your restoration partation or get a good working copy or XP to install from.
Oct 20, 2009 | Microsoft Windows XP Home Edition
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Windows XP won't start
for that you need winxp bootabler disk.
Tehn boot your computer with tht and go to recoverry console.
Then type in command prompt "chkdsk /r"
then press "y"
then it fixc error on harddisk.
Then after completing it restart your computer and boot with harddisk then it ok.
Jun 20, 2009 | Computers & Internet
It is possible to remove the domain login and networking setup, but you need to remove programs and cleanup/remove some registry items.
The best way to fix your problem is to wipe the hard disk and install Windows again. The Windows licence label is on the bottom of the laptop, use this product code to install Windows, you can borrow a Windows CD to do the install. Don't forget to download the device drivers from the Toshiba WEB site before you format your hard disk. You need to install your programs again as well.
If this is too hard then the easiest option is to put up with the login problem.
Jan 17, 2009 | Computers & Internet
After a hard drive falure I need to install windows xp
At this moment I have taken the HDD out of the case, bought an adapter for its 1.8" interfce and proceeded over the USB. I was, however, installing Linux, with practically no experience with Windows.
Oct 21, 2008 | Toshiba Portege R100 Tablet PC
Toshiba Portege R100 Notebook Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
