Question about Nokia 6500 Slide Cellular Phone
The down arrow key is not working at all. Before it did something similar but I clicked it a few times and it worked but now it is not working at all.
    Master:
  • 329 Answers
Take it to a nearest service centre
Posted on Sep 02, 2010
How to fix keyboard
Hi
There is a strong possibility that the contacts for the key are dirty. This can be caused by spillage of small amounts of liquid (particularly sugar or similar in sweetened drinks) or dust/dirt having worked its way under the keyboard.
Two options here:
One : Get a local laptop techie to clean the keyboard (they may suggest option two)
Two : Get a local laptop techie to install a new keyboard (if they are still available)
Or you could try to do it yourself, BUT beware there are many pitfalls in stripping down laptops.
Hope this helps
Jun 15, 2014 | Computers & Internet
Tip
If resolution of monitor set to higher than it limit
Hello<br /> Many times it may happen that the resolution of the monitor is set to higher than its limit causes the monitor to be in off state and thus make the system inoperable to overcome such problem you can perform some usefull tips as follows<br /> Start the system, after a few minutes just click the Right mouse button and on the keyboard press Down Arrow key for "Seven times" then press Right Arrow key one time then press Down arrow key again once. Then press Enter. The resolution should set to be 800,600 thus Starts the Monitor again to normal
on Feb 07, 2011 | Computers & Internet
How to remove bios password in hp probook 4520
This i what i did:
hold windows key+arrow up & arrow down + power
when the screen comes let go, hit F10 rapidly
click on security factory defaults or something like that
and reboot - password is gone!
It may work on other models too?
Dec 18, 2013 | HEWLETT-PACKARD ProBook 4520s
I touched a button on the keyboard that turned the page sideways.. it turned it to the left. how do I turn the page right side up?
Actually you hit a combination of keys. Most likely you hit Ctrl+Alt and an arrow key. Try Ctrl+Alt+the up arrow. If that rotates the screen to upside down, repeat the combination twice more (or use Ctrl+Alt+the down arrow twice).
If that doesn't work, if you have a Windows OS, try the Screen Resolution or Graphics Display settings. Right click on the desktop anyplace with no running programs or icons, select Screen Resolution and then change the drop down for Orientation. This works on my desktops. For my laptop, it's the Graphic Display and then a similar orientation label.
I hope this helps.
Sep 10, 2013 | Logitech Y-RAZ71 Wireless Multimedia...
How do I change language setting on Vaillant VRT 392f boiler remote control
here mate try this it worked for me.
Press left key
Scroll till page 15
Code will say 000 - should be 1000
Press right key once change first digit to 1
Press right key again
Will be on C1 in top right hand corner
Scroll through C pages till A1
Two A1 pages looking for one that says de..utch
Click right key once and change to d.. English
Aug 04, 2012 | Water Heaters
How do i turn the brightness down
Right click anywhere in the blank area of the screen then click on properties the following screen should come upcomputer254_5.jpg
then click settings tab should then see a screen similar to this
Then look for your Graphic card properties for example after clicking Graphics Properties tab the following screen should give then the opportunity to change your settings
The above are some examples taken from my aspire desktop but should help you further resolving your problem with brightness
Hope this solves your problem
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
Dell mouse not responding; diagnostics results says test passed. mouse works on other PC
There is a very good chance it's one of two problems. First, while theoretically you can connect tons of USB products, sometimes USB ports can be kind of hinky... Try unplugging something else USB based and plugging in the mouse or try several different ports. Also be sure it's not plugged into a USB hub and is going directly into your computer. If this works play with the arrangement of your USB devices until you find a configuration that works, maybe you'll have to switch out a printer or external drive while using your USB mouse...
If this doesn't provide a solution the next thing to do is to uninstall the pointer device driver in device manager and allow it to re-install.
If you don't have an alternate mouse to complete the task, here is the keyboard shortcuts for Windows although depending on your version of Windows it may be slightly different.
-First hold the windows key and hit the r key (win+r)
this will bring up the run menu
-Next type mmc this will bring up a management console
-Next press the ALT key and hit the down arrow key
(this should drop down the file menu, if it doesn't please try ALT+F)
-Use the arrow key to scroll down to Add/Remove snap in and hit enter.
-Use the arrow key to scroll down to Device Manager and hit ALT+A to add the device manager to the console. Hit enter.
-Make sure local computer is selected if this menu comes up and hit enter.
-Hit enter one more time bringing you back to the console with the device manager added.
-Hit tab to get to the center console and scroll down to mouse.
(If tab isn't doing anything please hit the ALT key once.)
-Hit enter to open the tree if it isn't already
-Scroll down to mice and other pointing devices (or something along these lines) and hit the right arrow key to expand the tree again.
-Select the USB mouse with arrow keys
-Hit the alt key again then the down arrow (not together) and then the right arrow key until you get to the action menu and use the arrow key to go down to uninstall and hit enter.
-Wait a moment and then go back to the action menu (you may have to hit tab just keep trying tab and the down key (not together) until a menu opens. Go over to the action menu again and choose scan for hardware changes. The computer should recognize the mouse and now work.
I hope this helps you. Thank you.
Jan 04, 2011 | Dell U0636 Mouse
Q208 no sound
try using the following keys. The FN key with the right or left arrow keys..
The FN key iss the bottom left corner key... The right arrow key is to turn the volume down... the left arrow key is to turn the volume up..
If your still having issues on your screen there should be a little speaker down by the clock. Righ click it and go to Properties you might have something turned off or need to adjust something.
Nov 30, 2010 | Samsung Computers & Internet
Printer says printing document but will not print. anything
I had this same problem, and after 45 minutes with HP support, eventually managed to get it to print by turning the printer of and then holding down both arrow keys (left and right) at the same time while turning the printer back on. I held down the arrow keys until it said "Language: English" and then clicked through the prompts. It then restarted, and all was well again.
Other places mention doing this with the OK and Cancel keys, but that didn't do it for me - the arrow keys did.
Jun 24, 2008 | HP LaserJet 2605dn Printer
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Nokia 6500 Slide Cellular Phone Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
