Question about Philips DVP3040 DVD Player
Hi!do not read any disc,bad disc on display...DVP3040 Philips
My dvd player phillips dvp3040/37 always shows "no
Hi tcpascual,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 20, 2011 | Philips Televison & Video
My dvd player phillips dvp3040/37 always shows "no disc". please help me.
Get a dvd cleaner disc. Or take it apart and clean it. Sounds like a dirty lens.
Mar 20, 2011 | Philips DVP5140 DVD Player
I can not remember my Phillips dvd password ,can you help me get passed it...
Try using the password 136900. If this works for you, then using your remote, access the general setup menu and choose the Disc Unlock option.
Hope this helps!!
Jan 09, 2011 | Philips DVP3040 DVD Player
Phillips 3040 dvd player is asking for a password and I don't remember setting it for a password. How can I get past the password?
Try using the password 136900. If this works for you, then using your remote, go to the general set up menu and select the Disc Unlock option.
Hope this helps!!!!
Jan 08, 2011 | Philips DVP3040 DVD Player
Só le cd audio naum le dvd msg bad disc
Hi its look that you need to clean the laser lens
manualy open the cover press eject unplug the dvd leave the door open and with a qtips and alcool wipe gently the lens
and its done put the cover back and try it its should works
and make shure that you have a clean disk before try to play it
hope that will help you
regards Alan.
Oct 13, 2010 | Philips DVP3040 DVD Player
Hi, my philips dvd player model number dvp3360/05 has stopped reading disks. Wjen it loads a disk instead of going to the start screen it just goes blank and on the LED display it says title. Any ideas on...
There are several reasons why your DVD player would stop reading discs.
1. Bad or dirty lens
2. Bad disc spinner motor
3. Busted capacitors on the mailboard
If you can open up your DVD player. Try to check for these problems.
Mar 14, 2010 | Televison & Video
Need a drive belt for a philips dvp3040/37 its the belt that slides the door open and closed.
Hi: i search belt and head fo my tape recorder philips aq 6455 and philips d6350. Thanks.
Cryptato@gmail.com
Nov 01, 2009 | Philips DVP3040 DVD Player
Unlocking a Philips 3142
HELLO!
I think you will find this useful!
Switch on the player Then open the disc tray
Press 9879 and the region code number you want to set the player to.
Hope this helps you! (:-).
Aug 20, 2009 | Philips DVP3040 DVD Player
Dvd on lock
Dear friend,
Pls upgrade ur dvd player. the problem will be solved.
Mar 03, 2009 | Philips DVP3040 DVD Player
Change region code from europe to usa
1) Open tray
2) Press 99990 on remote
3) Unit will display a confirmation code of '0' on screen
OR
- Open tray.
- Press 98790 on the remote control
Oct 29, 2008 | Philips DVP3040 DVD Player
Philips DVP3040 DVD Player Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
