Question about HP LaserJet 2300 Printer
Error 52.00 Printer says cartridge installed. Looks all ready. Starts making a noice as if to print then stop within 1 second. Nothing shows on the print queue
    Problem Solver:
  • 17 Answers
52 error is a bad laser scanner. The scanner needs to be replaced. No other way to fix the problem. If you want an idea of cost call us at 262-993-1551.
Posted on Sep 02, 2010
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a Canon MP510 printer and have changed the print cartridges many times for refills but am now always getting error 6502. I've tried turning it on and off, unplugging it, holding down power button...
hi,
you mentioned that you turn off and on these is on of the solution of your problem
but in your case it doesn't work
error 6502 arise when ink tanks not snapped properly
follow the steps below
  1. Confirm that the printer is powered on and pull open the paper output tray .
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place.
note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
5.Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
1 -tank installed properly
2-not installed properly
6. check the status of each ink tank according to the way its lamp flashes.
  • - On: The printer is ready to print.
  • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • - Off: An error has occurred and the printer is not ready to print.
  1. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
  2. regards,
  3. cseian
Dec 16, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
    This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
    Oct 27, 2009 | HP PSC 1410 All-In-One InkJet Printer
    A big PGBK ink cartridge problem
    Call - 1-800-828-4040
    Verify they are installed correctly.
    Remove the print head or ink tanks properly following the procedure below.
    1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
    Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
    2. Open the paper output tray and pull down the inner cover.
    3. Remove the ink tanks by pressing the tab of each tank.
    Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
    ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
    raisephlocklever.gif To reinstall the Print Head and Ink Tanks
    1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
    putinphnlockit.gif2. Insert ink tanks into the print head.
    Press the mark 'PUSH' on the ink tank firmly until you hear a click.
    3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <1> The ink tanks are installed properly.
    <2> The ink tanks are not installed properly.
    Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
    4. Put back the inner cover and close the top cover.
    Note: When starting printing next time, the print head cleaning launches automatically.
    During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
    James Mac
    Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
    Memory error
    Just do 2 steps:
    1. Press Stop.
    2. If the display highlight "Resume". Press the OK (Check Button).
    The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
    At least, you can now print. The display will show back again to "Ready".
    Jul 23, 2008 | HP LaserJet 2420 Printer
    HP deskjet f340 all in one printer
    hi this is problem with Cartridge please cheak with Ok cartridge it should be working
    if this information is useful for u pls rate me .........
    thankyou....
    Jun 09, 2008 | HP PSC 2210 All-In-One InkJet Printer
    The printer apear to be dead!
    Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
    • The lights tell when the printer is working or when it needs attention.
    • The buttons help control the printer.
    Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
    All lights are off. The printer is off (asleep).
    Press the POWER buttonc00123886.jpg to turn the printer on.
    The printer should turn on automatically when a print job is sent to it. c00123898.jpg
    The POWER (top) light is on. The printer is idle.
    The POWER (top) light is blinking. The printer is busy printing.
    Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
    The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
    • The front cover is open. Make sure the front cover is completely closed.
    • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
    • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
    Black: 51645A
    Color: C1823D,
    If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
    If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
    Jan 20, 2008 | HP DeskJet 710c InkJet Printer
    HP LaserJet 2300 Printer Logo
    169 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
