Question about Dishwashers
Dishwasher My dishwasher has suddenly stopped draining. I have removed the screen at the bottom and the majority of the water. What is the best way to check for a clog?
  • 413 Answers
Has a disposer been installed recently? If so the drain plug may not have been removed...... Some DW have a check valve attached to the sump that may have a blockage..... Remove the drain hose from the disposer, if connected to one and inspect for blockage.
Posted on May 29, 2008
    Genius:
  • 1,073 Answers
Inspect the pump and housing for a restriction
Posted on May 11, 2008
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
Hi , my adp4601 start light flashes four times and then flashes again constantly but not all the water is gone from the bottom can anyone help
If your Dishwasher is not Draining check the following
PISTON VALVE
On some dishwashers that have a filter (screen) along the back wall of the tub have a piston valve. The piston valve commonly causes dishwashers not to pump out. if your dishwasher does have a filter, remove it. Now remove the piston valve located in the center behind the filter. Now to check the piston valve, press up on the spring. Once done the piston should stop up the hole in the top of the valve. When a piston valve, is bad the piston dissolves to the point that it can no longer stop up the hole, in this case replace it.
DRAIN SOLENOID
Another common problem on some dishwashers that will cause it not to drain properly is the drain solenoid. To check this, first disconnect power from dishwasher then remove the bottom panel of dishwasher. Once off, you should see the drain solenoid attached to the main pump then reach under the dishwasher and push down on the solenoid. If it will not move down it is bad and needs replacing. If it will push, down most of the time it is good but not always so follow these steps as well. Reconnect power to dishwasher, now start the dishwasher in to a cycle. If you have a mechanical timer turn it slowly until the solenoid energizes. If you turn the timer all the way around and the solenoid never energizes replace the solenoid. If you have an electronic control, start the dishwasher and wait a few minutes then push start/reset then the drain solenoid should energizes, if not replace the solenoid. At times the timer will cause this part to go bad especially if its melted or frozen down. So you may have to replace timeras well.
CHECK VALVE
If your dishwasher is not draining properly, the check valve may be your problem. The check valve will be on some dishwashers with both a separate drain pump or drain valve (note if you do not have both you will not have a check valve). The check valve will be located where the black hose connects to the drain pump. To access the check valve, you must first remove the water from the dishwasher. A Wet-Vac works well. After the water is out, disconnect power to dishwasher. Now remove the dishwasher from under the cabinet. Now remove the black hose (even though you removed the water you will still have water in the pump so be ready).Once off you should see the check valve. It's the little red rubber flap. If it is torn off, the flap may have gone down the drain but you still should see the red ring left behind, in this case replace the valve. Sometimes the check valve will swell up and hang in the pump, if so replace it.
DRAIN PUMP
If your dishwasher is not draining properly, the drain pump may be your problem. As stated before, not all dishwashers will have a drain pump. To check this, First check to see if it is getting power. You should have 120 volts when the dishwasher is put into a drain cycle. If you have power and the pump does not run remove the pump and check for obstructions if none found replace the pump.
DRAIN HOSE
If your dishwasher is not draining properly, the drain hose may be stopped up. To check, remove all the water from tub. A Wet-Vac works well for this. After the water is gone remove the drain hose (even though you removed the water you will still have water in the pump so be ready) from the house plumbing and the dishwasher. Check for obstructions and remove. If you just installed a new garbage disposal check that the metal knockout was removed. Check the air gap if this is not right your dishwasher will siphon water back into it.
Use the VOM .God bless you21780fd0-aaed-4d92-83ce-067c50992eb6.gif4bac03e7-5a24-4d38-af39-6ddd621cc090.jpg
Apr 04, 2013 | Dishwashers
Aeg favorit 35085 not draining
PISTON VALVE
DRAIN SOLENOID
Another common problem on some dishwashers that will cause it not to drain properly is the drain solenoid. To check this, first disconnect power from dishwasher then remove the bottom panel of dishwasher. Once off, you should see the drain solenoid attached to the main pump then reach under the dishwasher and push down on the solenoid. If it will not move down it is bad and needs replacing. If it will push, down most of the time it is good but not always so follow these steps as well. Reconnect power to dishwasher, now start the dishwasher in to a cycle. If you have a mechanical timer turn it slowly until the solenoid energizes. If you turn the timer all the way around and the solenoid never energizes replace the solenoid. If you have an electronic control, start the dishwasher and wait a few minutes then push start/reset then the drain solenoid should energizes, if not replace the solenoid. At times the timer will cause this part to go bad especially if its melted or frozen down. So you may have to replace timer as well.
CHECK VALVE
If your dishwasher is not draining properly, the check valve may be your problem. The check valve will be on some dishwashers with both a separate drain pump or drain valve(note if you do not have both you will not have a check valve). The check valve will be located where the black hose connects to the drain pump. To access the check valve, you must first remove the water from the dishwasher. A Wet-Vac works well. After the water is out, disconnect power to dishwasher. Now remove the dishwasher from under the cabinet. Now remove the black hose (even though you removed the water you will still have water in the pump so be ready).Once off you should see the check valve. It's the little red rubber flap. If it is torn off, the flap may have gone down the drain but you still should see the red ring left behind, in this case replace the valve. Sometimes the check valve will swell up and hang in the pump, if so replace it.
DRAIN PUMP
DRAIN HOSE
If your dishwasher is not draining properly, the drain hose may be stopped up. To check, remove all the water from tub. A Wet-Vac works well for this. After the water is gone remove the drain hose (even though you removed the water you will still have water in the pump so be ready) from the house plumbing and the dishwasher. Check for obstructions and remove. If you just installed a new garbage disposal check that the metal knockout was removed.. Check the air gap if this is not right your dishwasher will siphon water back into it.
Use THE VOM.God bless you12567004-0afb-4605-8b5d-f8507096ff31.jpg9456b97a-bc1b-4d19-bb59-a6584bc4f997.gif
Water in bottom of dishwasher after it has run it cycle
check your drain - perhaps the filter in the bottom of the dishwasher is plugged (look inside the door, remove bottom rack and inspect with a flash light.
otherwise check your trap or where ever you have your drain hose hooked to drain...
Best regards
Ck
Aug 18, 2011 | Frigidaire Dishwashers
Asko dishwasher did not finish complete washing cycle and now has a very low humming sound. It will not start washing cycle. I have turned it on and off but after I turn it back on humming sound...
Some wash water may have gotten into the bottom pan area below the wash tub. If water has overflowed from the tub into the bottom pan, the drain pump will activate and remain active until water has been removed from the bottom pan. To check for this, the lower front panels will need to be removed. With power turned off at the breaker, a wet-vac can be used to remove water from the bottom pan. If there was water there, check the door seals, door closure and make sure the drain hose has a high-drain loop. If the drain is shared with the kitchen sink, it may simply have backed up into the dishwasher through the drain hose when a full sink was emptied. The best drain system is for the dishwasher to have its own separate drain.
Jun 29, 2011 | Asko Dishwashers
The dishwasher won't drain
First thing try maybe a shop vac or cup to try to remove water out of bottom of dish washer to gain acess to the screen to check it out.
If you have to use a cup the last little bit if you have a turkey blaster you can get the last little bit up.
Food will settle in it and stop it up that is the most common reason for drain problem's hope this helps you out.
Once all water removed to acess it remove screen and clean if needed. Next you may have to remove drain hose to clean it.
Aug 15, 2010 | GE Dishwashers
The dishwasher did not drain. What is the best way to unclog the drain?
Remove water out of dish washer to acess the screen to clean it out in the bottom. Once it is clean you may have to remove the drain hose to clean it out.
You may be able to remove water with a shop vac or cup to get water out of washer to check it out.
Food will get in the bottom at screen or past it and lodge in right before going to pump to stop it up.
Aug 14, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
I have standing water in my dishwasher. How do I unclog the drain?
It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
Aug 10, 2010 | Frigidaire Dishwashers
The dishwasher will not drain.
Check your main drain system. Remove the drain hose from that end and discharge them in a bucket. Try a new wash an if the m/c drain system is ok, it will discharge water in the bucket.
Check the house main drain for clogging at the hose connecting end.
May 25, 2010 | Bosch SHU5315UC Dishwasher
Pump still going. Dishwasher flooded last week and pump still going every time i switch it back on. I have left off for 3 days and I have tried the reset.
Check the following:
You'll need to get the water out of the bottom of the dishwasher - a wet vac usually works the best.
Remove the bottom rack and check the pump inlet screen in the bottom of the dishwasher for debris - it would be best to remove the screen and look for anything that may be preventing water from entering the pump.
The sink, at least the side where the dishwasher drains to be sure it isn't plugged
The discharge hose from the dishwasher to be sure it isn't obstructed somehow - you may to remove it to be sure. Check the discharge line check valve assembly to be sure it isn't stuck with something
You could have a control board issue, but if the pump is running, it should pump.
Jan 05, 2010 | Dishwashers
Open Questions:
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
