Question about Tech Solution TS-4500 Shredder
I have a paper jam. Reversing doesn't bring it up enough to grab it. Cooled it off. Reading about shredder oil. Haven't found it nearby. Can any other machine oil be used?
    Problem Solver:
  • 10 Answers
Try graphite powder which you can purchase at a hobby shop or home builder supply - or try rubbing with pencil lead. However, I have also, carefully and observantly, taken the shredder head apart to release pressure on the teeth. After some of the stuck paper falls out, put it back together and try again. Be sure safety guide is in place so it work properly when you put it back together.
Posted on Sep 02, 2010
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
    Instructions
    Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
    Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
    Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
    Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
    Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
    Good Luck!
    Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
    It will not grab the paper; need to press forwared
    Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
    If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
    May 24, 2010 | Quartet gbc Shredmaster 6550X...
    Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
    May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
    Jam
    I work with Fellowes shredders so I can't tell you about the automode but to get out the jam you can try this:
    Remove as much paper as you can with a needlenose pliers or something with a good grip from both the top and bottom of the shredder than saturate any paper left in the machine with a vegetable based oil only do not use any petroleum based oil (may cause fire)
    Let that soak for up to 8 hours this should soften up the paper enough to let you power thru the jam as soon as you get power. You should be able to do a search online to find a customer service number for your shredders manufacturer. Good Luck!
    Feb 28, 2008 | Aurora Global AS702MX Shredder
    How to fix a stuck shredder
    Go to your local hardware store, and pick up a quart of 3 in 1 oil, shredder oil or some other light weight oil. (With the shredder in the off position or unplugged). Use a couple of ounces and Pour the oil over the paper that is jammed in the shredder. Use enough oil so it saturated the jammed paper. Wait about 10 - 15 minutes so the oil really soaks into the paper. Don't go crazy with the oil, and keep in mind what goes in, must come out. If you pour too much oil in the shredder, the exess oil will drip out. Don't worry about having oil in the shredder blade, this will help lubricated the teeth, and it will actually make your shredder blades last longer.
    Now try to turn your shredder on after the oil has soaked into the paper for 10-15 minutes. Hopefully, the paper that is stuck has gotten softer, and then it should pass the paper. If it still doesnt work, then, try some more oil on the paper, and then wait and then turn the shredder to the forward, and then reverse mode, and then back and forth.
    Hopefully your shredder will be unclogged by this time.
    Hope this helps.
    Good luck.
    Feb 04, 2008 | Office Equipment & Supplies
    Huge paper jam ( piece of a checkbook)
    Throw it out and buy a new one! staples won't replace this unit and your gonna have to take it apart and clean the gears.
    Also tell your employees to stop reversing the drive gears with paper inside the bucket it only reverses the flow and jams the unit.
    I would buy a cross cut shredder next time.
    Hope that helps.
    Jan 19, 2008 | Techko SH1524CP Shredder
    Something is jammed
    I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
    Jan 08, 2008 | Office Equipment & Supplies
    Paper Jam
    try to remove as much as possible from top and bottom of unit with a needle nose pliers or similar tool after that you can saturate any left over paper with shredder oil or a vegetable based LIQUID cooking oil. Let sit for 7-8 hours this should soften the paper enough to power thru the jam.
    Nov 02, 2007 | Royal JS800 Shredder
    Jammed
    You need to remove as much of the jam as possible then saturate whatever is left in the machine with a vegetable based liquid oil let soak for 8 hours or more this should soften paper enough to power thru jam.
    Oct 17, 2007 | Cross Brinks S9855W -Cut Paper Shredder
    Tech Solution TS-4500 Shredder Logo
    66 people viewed this question
    Top Tech Solution Office Equipment & Supplies Experts
    Jim Keysor
    quennie732
    Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
